19psi's Avatar
I wish this wasn't 700+ miles away. Transport looks to be between $600 to $700...too much.
Biggest vehicle I have is a 1998 Olds Bravada. I'm afraid a full U-Haul car trailer and a 928 would be pushing its limits.
George in Indiana
928 Weissach #153
Cayenne S
Old 12-03-2011, 04:45 PM
One possibility is trust bearing failure, crank shaft dug itself into the block...., that would cause the crank assembly to seize.
How was the car doing before? Did it ever shut down while getting to a stop light or stop sign?
How long you have had it for and how many miles you put on it?
Also what kind of oil did you used in it, brand and weight?
Ali
Old 12-03-2011, 05:05 PM
Recovering dismantler
neil30076's Avatar
I'm going with the TBF as well, its an auto, no known history - have you taken a look at the oil - pull the dipstick, let the oil drip onto a piece of white card, and then examine under a very bright light - do you see shiny specs in it - indicative of tbf or main bearing failure.
Neil
2009 Mini Cooper
2004 Mercedes CLK500
2024 Subaru Outback Touring XT
2020 Entegra Coach
Old 12-04-2011, 01:47 PM
Petie3rd
Mrmerlin's Avatar
Neil if you use the dripping oil test it will work better if you use a black piece of cardboard ,
and look at the oil in the sun the metallic particles show up better with black background
Old 12-04-2011, 02:13 PM
neil30076's Avatar
Good point Stan. Also i found that using a flourescing light source on the end of a boroscope and therefore much closer up can sometimes yield better results.
Neil
2009 Mini Cooper
2020 Entegra Coach
Old 12-04-2011, 02:42 PM
928: Serial Enabler
I'd probably want to get it into the air and change the oil.
The car looks very good in pictures.
I'd be hitting it with the paddles until security dragged me off.
84,85,86 928 cars
Old 12-04-2011, 05:21 PM
Rockin' NW Arkansas
firefighter7128's Avatar
Send a message via Yahoo to firefighter7128
Ali
Recently, (as it has gotten much colder) the car needs a bit of help ideling while warming up. it wanted to idle at 200rpm. if not warm enough, it would stall on me but no prob to re-start. I hadnt looked into it but assumed it was the idle control.
Had the car 6 weeks. I got the title in the mail the day it broke down. Joy! When I bought it, I took it right to my own mechanic and he did a visual inspection on the belt, changed the oil and gave me a list of things to start on such as leaking PS pump and of course the same side ball joint. Other minor issues. He did a tranny filter change, oil change, topped of fluids and new plugs.
He said the belt looked new and that it was good, metel braided, reinforced belt.
Matt
1986 Porsche 928 S - Daily Driver
1984 928 S - SOLD, 1986 944 S - SOLD, 1988 944 S - SOLD
Old 12-04-2011, 06:20 PM
Petie3rd
Mrmerlin's Avatar
Matt please post pictures of the belt
Old 12-04-2011, 06:22 PM
Swapper and Ruiner
not_hans_stuck's Avatar
Sorry to hear that dude. race-cars.com has a motor for sale.
But I wouldn't waste my money on another one of gigantor motors that don't make any horsepower.
I'd do an LS-3 conversion and give it some real beans.
H
http://forums.pelicanparts.com/paint-bodywork-discussion-forum/502929-diy-iroc-rsr-conversion.html
http://forums.pelicanparts.com/porsche-911-technical-forum/649179-rsr-ls-conversion.html
Old 12-04-2011, 06:26 PM
What kind of oil did your mechanic put in your engine? what weight was it?
Old 12-04-2011, 07:51 PM
Network Native
Danglerb's Avatar
TBF I'm thinking is usually hot start issues, but eventually thunk, block etc is toast.
Old 12-04-2011, 08:08 PM
MPDano's Avatar
You can never go by "looks good" with these belts. Rubber degrades over time. Unless you had good history on the car when you bought it, it's one of the very first things that are changed out. Same with Water Pump and Fuel Lines.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 12-05-2011, 05:44 AM
davetr's Avatar
dammmmmm id pay $1000 for that
Old 12-05-2011, 07:54 AM
MPDano's Avatar
Be done with this thread and go save it!
Old 12-05-2011, 09:22 AM
Rockin' NW Arkansas
Got a buyer. Guy has a few 928's and I think a member of this board. Picking up on Wednesday
Matt
Old 12-05-2011, 09:57 AM
harborman's Avatar
Well great and good luck. Now you can look for another 928 and hopefully find a nice one some day.
1986 928S
32 valve engine
All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires.
Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster
Old 12-06-2011, 05:38 AM
davetr's Avatar
best of luck to th new owner
Old 12-06-2011, 07:43 AM
You might let the new owner know that there is an 80k mile S3 engine listed on R-list right now for $900 IIRC.
Mike
Old 12-07-2011, 06:51 PM
