fuel pump ?
i just recieved a new fuel pump today,the outlet is diff. than the old one. it has a threaded end and holes in it and screws in,do i need a diff. connector and where do i find one? any help?
Not sure which year you have. My 86 has a check valve which screws into one end. What does your old one look like in comparison? Take a picture and post it here.
1986 928S 32 valve engine All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires. Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster |
In your "signature area" post your year and model so the guys have a better idea on helping you out.
its an 80', both ends are the same. straight shaft with a nipple for the hose clamp. old one is still on car,no pics only from phone-sorry
Where did you buy the pump? Part Number? CIS or L-Jet? You really need to put your MY and US or Euro in your Sig "And" you need to buy a digital camera.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior 1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD** ![]() |
Someone with your year should be able to set you right. Again, post your year and model in the signature area so every time you respond it will be in there.
This is L-Jet
![]() This is CIS ![]()
Thanks for helping him out!
thanks-its silver but has the L-jet end thought my info was on there-will check! should be
Ok? Color doesn't matter, it's the connectors. The pictured is the one you received or is "on" the car?
it looks just like the L-Jet one
whats the differance? L-Jet and CIS?
928: Serial Enabler
Where did you get it?
What is the part number. Did you try to substitute something else, not the right Bosch pump, as there are hundreds of them. Get a real camera.
84,85,86 928 cars |
Bosch Fuel Pumps -
Hey Nuts4Porsche, All of the Bosch designed fuel pumps are pretty similar in appearance except for the delivery capacity and how the output check valve is attached. Part numbers and vehicle engine size (Fuel needed for Max HP @ full tilt wide open throttle) will determine each application.
Referring to the above photos - The output check valve is built into the snout of the earlier all silver pump while a removable check valve is shown attached at the output end of the green colored pump. Both pump setups have a soft rubber hose on the inlet side and a banjo style fuel line fitting on the high pressure output side. The check valve along with a spring loaded fuel accumulator is designed to hold a static/residual fuel pressure at the fuel injectors for restarting a parked vehicle. The problem with the earlier silver design (snout) pump was that if the built-in check valve fails to seat and hold your residual fuel pressure - you had to replaced the whole pump as an assembly. On the later designed pumps, if the output check valve fails to seat - it can be replaced as a separate part. By the way - you can actually add the separate check valve to the output side of the earlier silver fuel pumps. In some cases I had found that if an older (snout) style fuel pump was still providing good solid fuel pressure/quantity while the engine was running, you can simply stack on a new check valve to resolve a static fuel pressure problem. This does make the older pump assembly a bit long…..but it can save you the price of a replacement pump. One other point - If you are having a difficult time restarting a parked car from the loss of your residual pressure - also statically check all your injectors and the fuel accumulator for leaks. The silver snout fuel pump uses a bolt with holes drilled through it - to attach the banjo fuel fitting. This bolt looks almost like the check valve you can see screwed into the newer style pump. The new stye pump with detachable check valve needs only an acorn cap nut to attache the banjo fitting. Good Luck, Michael ![]()
1984 928S - "Miss Purdy" 1987 911SC - "Frau Helga" 1986 930 - "Well Hung" 1975 911 Targa "Blue" Last edited by JK McDonald; 12-08-2011 at 04:34 PM.. |
fuel pump ?
I do have a good camara! the car is stored for the winter. i bought the pump off a website from a porsche race i went to. ill post a pic of the new one,just wanted to know if it would work for my car.u guysknow your stuff,so i asked. thanks for all the quick info,helps alot! have 4 kids up my*** tryn to use the computer.
80 US auto |
electric performancefuel pumps
80 US auto |
The difference is the fuel pressure. If you use the wrong pump, your car will run, and it will idle, however, when you attempt to rev your engine under load, you will find that it will not.
Good Luck.
John Curry (Drift King) 928OC member Grand Prix White 1994 GTS AT (The GTS) Black 1989 GT (The GT) and Cobalt Blue 1989 S4 AT (The Blue Car) 1986 Euro AT Indishrot 1984 Euro S AT (The Stepson) and Black Metallic 1984 Euro S 5 speed (The Schwartz) |
so, how do i find out if i can use it or not? has no markings...nothing the site said it was for my make,model,year if updated to the present pump- will it work,right?
80 US auto |
got the pump for $123.45 to my door,not 300 -500. FYI part # PRF P1027K
80 US auto |
'79 928 Euro 5 Speed
Send it back and buy this one on Ebay for $39 shipped to your door:
Its what I did (and I will most likely take some flack for using the cheap pump, but its working great).
'79 Porsche 928, '00 Porsche Boxster, '86 Porsche 944, '04 BMW Z4 '77 Fiat Spider 124,'07 Chevy Suburban LTZ '83 Jeep CJ7, '06 Harley Sportster |
