GT block Interchangeable with the S4 block
Rebuilding my 1988 S4 engine . Can I use a 1989 GT block? Also where on the block is the block type imprinted? Thanks a lot.
Old 01-26-2012, 07:58 AM
Network Native
Danglerb's Avatar
Motor ID is stamped into a flat spot at the top front of the block, look straight down from the upper hose to the radiator and you should see it, something like M28/44 and serial number.
89 GT is a rare car, the block could have some value to a numbers correct owner. You might want to consider selling it. I think it should work though.
Old 01-26-2012, 08:31 AM
Thanks for the information.
Old 01-26-2012, 10:05 AM
Petie3rd
Mrmerlin's Avatar
can you please add more info about what your doing?
Why use a GT block what happened to the S4 block?
The girdle of each block is machined to each block.
so these parts must be kept together.
Piston assemblies must also be of the correct tolerance group,
stamped above each bore 1,2,3
Old 01-26-2012, 10:36 AM
My engine has locked up. I suspect the thrust bearing only because I inspected the flex plate and it was bent forward. I have not torn into it yet. What I have read is that the block and crankshaft becomes scored and unrepairable. I am also looking for a complete engine.
Old 01-26-2012, 01:41 PM
Petie3rd
Mrmerlin's Avatar
if you had thrust bearing failure then the whole engine is now contaminated with metal as well as the oil cooler. If so then the valve tappets should be replaced unless you can take them apart , the cam journals may also be scored so new heads may be needed .
A complete engine would probably be the best course of action to repair the car also flush out or replace the oil cooler.
The oil can be checked by getting a sample of the oil dripping it onto a black piece of cardboard,
then looking at the oil in the sun you will see lots of metallic particles , if so then you can figure thrust bearing failure
Old 01-26-2012, 02:46 PM
Architecture & Porsche's
drain plug should have flakes of steel all over it. Oil filter too.
Porsche Club Racing National Scrutineer
'89 Andial 951
'82 928R
'74 911 RSR 3.6
Old 01-26-2012, 03:16 PM
Actually, are not flakes of aluminum? In my very limited experience with 2 failed engines the flakes were all aluminum....didn't find any steel flakes at all....
1956 Intermeccanica 356 Speedster (sold),1957 Intermeccanica 356 Speedster (sold),,1985.5 Porsche 944 (sold),1955 Thunder Ranch 550 Spyder (sold), 1955 Outlaw 356 Speedster (currently in build out), 1984 Porsche 928S (White), 1984 Porsche 928S (Red)
Old 01-26-2012, 04:00 PM
Network Native
Danglerb's Avatar
First step, find out what is actually wrong with the engine.
Old 01-26-2012, 09:22 PM
I want to thank everybody for their help. There is a lot of insightful information. I will start with the oil. I do not know the history of this car, but looks like a fun project especially with all the help. Thanks and I will keep on posting with my progress.
Old 01-27-2012, 03:58 AM
PCA Certified D.I.
I just completed the knuckle busting part of your project. I'm now into the head scratching, hair pulling part of "why the !@#$$ won't start. Slowly eliminating possible reasons.
1986, '87,'88 928S4, 2006 Cayman S Cabluey, 2006 Cayman S "Burn Notice"
Old 01-30-2012, 07:36 AM
stepson's Avatar
Give us additional symptoms and what you have done so far. There are some really smart folk on this forum that might be able to give you guidance.
John Curry (Drift King) 928OC member
Grand Prix White 1994 GTS AT (The GTS)
Black 1989 GT (The GT) and Cobalt Blue 1989 S4 AT (The Blue Car) 1986 Euro AT
Indishrot 1984 Euro S AT (The Stepson) and Black Metallic 1984 Euro S 5 speed (The Schwartz)
Old 01-30-2012, 09:50 AM
Petie3rd
Mrmerlin's Avatar
can the engine be turned by hand?
do the timing marks line up?
Are there metallic specs in the oil?
Old 01-30-2012, 04:38 PM
I am in the process of removing the engine from the car. I cannot turn the motor over at all. I drained the oil and could not see any metal. The oil was pretty thick. I purchased the car knowing the engine did not turn but the former owner did not know what happened except it stopped running. I will have the motor out by this weekend and plan on looking in the oil pan first or is there any suggestions on the sequence I should take on investigating the problem. All this help is appreciated.
Old 02-01-2012, 08:39 AM
Could be a dropped valve: keeping it to rotating: try rotating it a wee-bit backwards.
Also is the engine disconnected from the drivetrain?
Mark
'89 Andial 951
'82 928R
'74 911 RSR 3.6
Old 02-01-2012, 08:43 AM
Yes I have separated it. There are only 8 bolts left to bring it out. The engine mount bolts. I do not get home until after dark so I am going to wait until Sat. I will try that. Over the last 2 weeks I was thinking maybe the pistons might be frozen so I poured some transmisson fluid to break it up. No luck yet.
Old 02-01-2012, 10:14 AM
By the way I am still looking for a short block or an entire engine. The GT block was not a GT block. It was an S4. By the time I was ready to buy someone else bought it. Oh well.
Old 02-01-2012, 10:56 AM
Last night I tried to rotate counterclockwise. It is frozen in both directions. This weekend I will pull the engine and look inside. I am very curious what is locking it up. I will post with my findings.
Old 02-02-2012, 04:42 AM
Network Native
Danglerb's Avatar
Locked up might not be so bad, whats the history?
The DMV often shows 89 to 91 as S4 GT which can confuse people, but a GT motor is worth twice or more what a S4 is.
Old 02-02-2012, 09:47 AM
The car is a 1988 S4. Engine is a 5.0L 32v M28/42. I purchased the car from someone who does not have any records and could not tell me what happened. I believe he bought it and then just turned around and resold it.
Should I take the heads off first or work below and open up the oil pan. I have the engine 99% out. I just have the eight motor mount bolts left to remove. Thanks.
Old 02-03-2012, 05:25 AM
