1984 928S 5spd. Red
New guy
Hi I am new to the forum and to Porsche. This is my first. Just bought it today it has new brakes calipers suspension ball joints timing belt injectors plugs wires etc. Starts and runs well. (at least it did when I picked it up to put it on the trailer) and when I took it for a 3 mi. test run. Went out to start it a little later and it started right up ran for 30 sec. and died. Would not start for about 5min. then it started idled for a min or two and died again. Hoping it is just a little moisture in the gas. The other problem I have is that it has all new brakes but the left rear brake will sometimes not release and you have to release the pressure manually. I am thinking the brakes just need a good flushing? Of course it has the prerequisite electrical gremlins but all in all I think it was ok for 1300. I have worked on cars for many years (mostly Z's and AMC's) so I will probably be asking for a lot of help because this is a whole different animal. Sorry for such a long post and thanks in advance for all the help
Old 02-12-2012, 07:01 PM
'79 928 Euro 5 Speed
Rupesy's Avatar
Welcome to 928s and the forum! You will definitely find lots of help here. We love pics so post them when you are working on something.
One of the first places to start with these cars (in general) would be the fuse panel located on the passenger side foot well. Remove every fuse (there are lots) and clean the contacts, clean the fuses and check for continuity. Also, everyone here is adamant about proper grounding. A basic search in grounding (and fuse panel) should turn up a bunch of pics on all the ground points and fuse panel info.
'79 Porsche 928, '00 Porsche Boxster,
'86 Porsche 944, '04 BMW Z4
'77 Fiat Spider 124,'07 Chevy Suburban LTZ
'83 Jeep CJ7, '06 Harley Sportster
Old 02-12-2012, 07:19 PM
Rupesy's Avatar
What info did the previous owner provide when they said all new brake calipers? How long ago were they installed and was this car a daily driver or did it sit for a long time? Were they installed by a shop or himself? Can you physically see they are new? It seems as though the system would have got a flushing when they installed the new calipers. A caliper that is hanging up usually has contamination or rust on the piston due to a torn boot. Or they were not careful when installing new pads and shoved the pistons back without cleaning.
I would pull it off and have a close look. Maybe post a picture or two.
Old 02-12-2012, 07:38 PM
MPDano's Avatar
Welcome to the Board and the World of 928's. Like Rupesy said, "grounds, grounds and grounds." Here is a good Topic for some known issues and fixes.
**MOST Common 928 Issues AND Fixes**
Now the next thing we like here is Pics, pics and more pics. Also, make sure to post your Model Year in your Profile Signature.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 02-12-2012, 09:34 PM
Network Native
Danglerb's Avatar
Welcome to the forum and ownership of the finest car ever made.
I don't think I would trust anything the previous owner touched if the brakes aren't right. Best to do it before you buy, but still IMHO required is an inspection by someone expert in the 928 to get you a baseline on what needs to be done.
Old 02-12-2012, 11:34 PM
Engineer of profanity
924CarreraGTP's Avatar
Me likey! The Porsche 928 is a truly awesome machine. The naysayers were always and still are wrong about them.
1970 Porsche 911T Black
1990 Porsche 944 S2 Red on cashmere
1984 Porsche 928S Euro ROW GP white on black
Old 02-13-2012, 12:13 AM
1984 928S 5spd. Red
Thanks for the replies. The previous owner drove the car from time to time in the summer. The previous owner did the fuse panel as was suggested in an earlier reply. I intend to start with new grounds and go from there. The previous owner had everything working but the car recently lost the brake lights, but most of the rest of the electrical system seems to function. I will tear into the brakes this weekend and will probably have questions at that time. Thanks again
Old 02-13-2012, 04:22 AM
Welcome. I'm a recent new owner as well. My recommendation? There are several forums that contain TONS of information on the 928. The main ones I frequent are Pelican and Rennlist. Chances are any problem you enconter has already been seen and solved by someone else.
Present: 1984 928S/Indischrot, 1994 968/Polar Silver
Past: 1979 911SC Targa/Petrol Blue
Old 02-13-2012, 04:29 AM
stepson's Avatar
What year is your car? That information will greatly help subsequent diagnosis of your issues. It would be great if you could put the model year in your signature line.
And congratulations on your purchase!
John Curry (Drift King) 928OC member
Grand Prix White 1994 GTS AT (The GTS)
Black 1989 GT (The GT) and Cobalt Blue 1989 S4 AT (The Blue Car) 1986 Euro AT
Indishrot 1984 Euro S AT (The Stepson) and Black Metallic 1984 Euro S 5 speed (The Schwartz)
Old 02-13-2012, 08:36 AM
1984 928S 5spd. Red
Sorry knowing the year would probably help in a number of ways. I'm not sure how to put it in my signature line but I will attempt to. My 928 is an 84.
Old 02-13-2012, 04:45 PM
