nuts4porsche's Avatar
alarm
i was on rennlist and saw a post for disabling the alarm,can anyone explain it,or have pics on how to do this? i think it maybe the cause of all my headaches! thanks
80 US auto
Old 02-14-2012, 01:48 PM
Network Native
Danglerb's Avatar
RL post was about the jumper used I think only in certain early models.
Most frequent alarm issues are from buried aftermarket units flaking away.
Old 02-14-2012, 02:00 PM
i have the alarm on mine and goes off constantly while workn on her. it causes fuel pump and ignition not to work and no starts! i think its a problem with mine and would like to disable it,but not sure what they were talkn about plug Z and jumping term. 1 and 6? i need pics or a good explanation on how to find and disable alarm. thanks all!
80 US auto
Old 02-14-2012, 02:07 PM
Maleficio's Avatar
You may have a faulty switch somewhere. The hood switch goes bad, it's on the passenger side right at the cross-member mount. Your hatch switch may be bad, too. I just disconnected my switch, the connector is right there at the receiver, near the battery ground point.
1982 Porsche 928, Auto, 4.5
http://i72.photobucket.com/albums/i166/hethaerto/928Mist2.jpg?t=1305333945
Old 02-14-2012, 02:18 PM
thanks-could it be the central warning system? the red light on the dash lights up too and the buzzer doesnt stop going off! are these the same or diff. systems? thanks
80 US auto
Old 02-14-2012, 02:27 PM
Maleficio's Avatar
Does it work properly? Leave a door open with the switch depressed by some tape, lock the car/activate the alarm, and remove the tape. If it works as it should, that should help you narrow down the culprit.
Old 02-14-2012, 04:28 PM
'79 928 Euro 5 Speed
Rupesy's Avatar
I know yours is a '80 US and mine is a '79 Euro, but I found mine behind the glove box. There was also a switch under the dash on the driver side that I could push in and pull out which I thought was supposed to shut it off but didn't always work. Got fed up and just started pulling out connectors. I wish I could remember which connector I pulled. I guess one day I will go back and see if I can figure it out. Anyway, this may not help at all, but thought I would post my experience.
'79 Porsche 928, '00 Porsche Boxster,
'86 Porsche 944, '04 BMW Z4
'77 Fiat Spider 124,'07 Chevy Suburban LTZ
'83 Jeep CJ7, '06 Harley Sportster
Old 02-14-2012, 06:40 PM
cool,ill check that to,any info on the CLS?
80 US auto
Old 02-14-2012, 07:18 PM
any help on the central warning system,it goes off constantly buzzing too and the red light "!" stays on,can you disable that to? thanks
80 US auto
Old 02-15-2012, 01:23 PM
