JGoatley's Avatar
Engine / Clutch noise
Hello,
My 81 Euro 5 speed has a very annoying noise between 2 and 3000 rpm's. Sounds like a cricket riding in the dash. It stops immediately if you hold in the clutch pedal and continue to rev the engine in that same range. I'm guessing pilot bearing. Does this sound logical? Any other possiblilities?
1981 Euro, 5 speed , Black
Old 03-31-2012, 06:42 PM
Kyle C
Pilot bearing is only under load when the clutch is disengaged, so that's probably not the source. I'm having trouble thinking of what that noise might be, throwout bearing is a possibility but in my experience it will make noise when the clutch is engaged and get worse/louder when the clutch pedal is pressed in (bearing under load).
1978 928 5spd hillclimb special
1984 928S 5spd, 1986.5 928S auto
1983 944, 1984 944 track car
1995 Saab 900 S, 1997 Saab 900 Turbo, 1999 Saab 9-3 S
Old 04-01-2012, 06:12 AM
JGoatley's Avatar
Thanks. That has been my experience as well as far as the throwout is concerned. It is definitely a bearing squeal that you hear if you are standing looking at the engine. Inside the car, it sounds like a cricket chirping. Very strange and very annoying as my car did not come with A/C so I have to drive with the windows open.
Could it be a bearing in the torque tube? I assumed the torque tube would only be the culprit if the car is in motion. This noise will occur with the car sitting still.
Old 04-01-2012, 09:50 AM
1978 928 - 9288200072
The transmission is in the back so the driveshaft spins when the engine is running and the clutch engaged. It would stop spinning when you depress the clutch pedal.
Rick
1978 928 - 5 speed - no sunroof - Copper Brown Metallic - Cork Interior
Old 04-01-2012, 09:55 AM
Petie3rd
Mrmerlin's Avatar
have you washed the engine?
if so then the wash water has probably gotten into the throw out bearing and its now going to fail the water will run down the release arm at the back of the engine on the top left side where the release arm connects,
The sounds you are hearing are the throwout bearing so its time to replace it
Old 04-01-2012, 12:05 PM
JGoatley's Avatar
Thanks Merlin. I have not washed the engine, but I have seen pictures from previous owner where his mechanic had pressure washed the bottom of the engine after working on some oil leaks. Looks like I will be reading up on pulling the clutch assembly.
Old 04-01-2012, 04:37 PM
