harborman's Avatar
Direct Injection
I keep hearing ads for direct injection and was wondering what the difference is between that and fuel injection. It appears fuel injection injects the gas into the manifold where as direct injection goes right into the cylinders.
1986 928S
32 valve engine
All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires.
Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster
Old 04-26-2012, 05:23 AM
Yes, that is correct. Think about fuel pressures above 2000 psi generated by pumps driven from camshafts etc. If you think a fuel line leak fire is bad in a 928, imagine one in a direct injection car.
Old 04-26-2012, 10:22 AM
harborman's Avatar
Sounds like one of those pressure washers!
1986 928S
32 valve engine
Old 04-27-2012, 04:49 AM
Maleficio's Avatar
One drawback: the lack of liquid fuel hitting the actual intake causes build-up of carbon that would normally be kept clear. Or so I've read.
1982 Porsche 928, Auto, 4.5
http://i72.photobucket.com/albums/i166/hethaerto/928Mist2.jpg?t=1305333945
Old 04-27-2012, 08:53 PM
IIRC the upside to direct injection is the cooling effect of the fuel on the piston crown allows higher compression without detonation.
Mike
Old 04-28-2012, 03:42 AM
Mike
Yup, my F-150 has the Ecoboost V6 in it. It has twin turbos running up to 15 pounds of boost with a 10.0:1 CR on 87 octane gas.
1986 Porsche 928S
2011 Ford F-150 Platinum EB
Old 04-28-2012, 05:26 AM
Maleficio's Avatar
damn
Old 04-28-2012, 12:24 PM
