83 US 928 Guards Red
O2 sensor madness
Can anyone explain to me the whole 2 wire vs. 3 wire O2 sensor issue? The old O2 sensor is a 2 wire, the new replacement sensor is a 3 wire...
Old 05-16-2012, 09:06 AM
Good read: Oxygen sensor - Wikipedia, the free encyclopedia
The probe typically has four wires attached to it: two for the lambda output, and two for the heater power, although some automakers use a common ground for the sensor element and heaters, resulting in three wires. Earlier non-electrically-heated sensors had one or two wires..
Basically 2 wire sensors had 50,000 wear cycle due to not being heated vs heated being double at around 100k.
My Car:
84' 928 S with Euro Mods - Quartz Gray Metallic (Quite the project!)
Old 05-16-2012, 10:55 AM
how would you recommend wiring a 3 wire sensor when its replacing a 2 wire sensor then?
Old 05-16-2012, 10:59 AM
is this for a US or euro 83? euro would be CIS and the 2 wire sensor added in federalizing it might have been jerry rigged. my us 84 uses 3 wire and its the same l-jet system as yours, something seems amiss here.....
My Car:
Old 05-16-2012, 12:50 PM
Thanks for the info everyone. I'm just going to say that I am apparantly brain-dead because it turns out that I have a 3 wire system all around, and don't know what I was thinking.
Old 05-16-2012, 03:38 PM
19psi's Avatar
Hey, a local Cheesetown guy! I'm in the Boone Grove/Hebron area.
Are you going to the car show in Valpo on the 27th?
George in Indiana
928 Weissach #153
Cayenne S
Old 05-16-2012, 04:19 PM
well i doubt my 928 will be there on the 27th, but i will be...
Old 05-17-2012, 10:48 AM
