jacking basics s4 87
this is a simple question, but thought any s4 owners might know.
this s4 has 4 jacking pads, but unlike other porsches i work on, there is no center jack point for the jack. i.e. under center of door sill bottom
i also see no main crossmember etc to lift the car. some porsches i can do the rear by lifting on rear jack pad, and then place the jackstand on the torsion bar for example
it seems that the jacking points are at exactly where i need to put the jack stands.
need some help here. thanks.
Old 05-31-2012, 10:17 AM
European Shark
riber.bentsen's Avatar
In the front I usually jack on the suspension mounting points.
In the rear you can jack on the transmission cradle crossmember without trouble - this will lift the entire rear end, but you need a shallow and long jack...
1978 Porsche 928 Euro 5spd. Silver metallic/Black
1986 Porsche 928 S2 Euro 5spd. Meteormetallic/Grey. *Crashed*
Owning a 928 is risky business - but sometimes you just gotta say "what the fudge".
Old 05-31-2012, 10:43 AM
jacking points s4
thanks. i will look for those areas. i guess in the front when you mention suspension mounting points, this means to control arm?
Old 05-31-2012, 01:01 PM
European Shark
Yup. Some have succes using a large block of wood on the chassis beam running right "behind" the jacking point, too. (Looking at the car from the side)
Old 05-31-2012, 01:39 PM
928 Newbie
dcrasta's Avatar
Yes where there control arm bolts to the frame rail there is a 'guard' or 'skid plate' .. I jack there and put the jack under.
You can also jack the rear jackpoint,and lift high enough to get the jackstand under the front jack point. If you do this on both sides (jacking at the rear jackpoint) till you get jackstnds under the front jackpoints then you can jack at the rear cross member and get jack stands under the rear jackpoints.
(dont be scared, the 928 has a very stiff uni-body so you can cross jack it that way without windows popping out and such..).
Old 05-31-2012, 01:40 PM
harborman's Avatar
I jack the back using a small block of wood on my floor jack and jack under the rear center support. On the front, I sometimes place the jack under a front skid plate and get the suspension up just enough to place my floor jack and 2' 2x4 centered on the jack and placed under the center support. Now you can lift the car front all at one time. I think Mrmerlin does it this way.
1986 928S
32 valve engine
All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires.
Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster
Old 05-31-2012, 02:20 PM
jacking points
Thanks for all replies...in the rear i can see center support under tranny and can lift there and put rear jackstands in place. For fronts...i see the different methods...there is a center plate right at steering rack i assume we do not want to lift there to get both fronts?
Old 06-03-2012, 05:22 PM
Consider a set of Porken liftbars: Liftbars
I would not be jacking up from anywhere other than the jack points.
Old 06-03-2012, 06:42 PM
Pete R's Avatar
I start at the back and use the tranny cradle to lift the car and place stands under the rear pads. I then move to the front and lift on where the front of the a arm bolts at the bottom of the skid plate. Since the car is on jack stands at the back it will lift even and you can place both front stands on the pads at once.
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold)
Neon SRT4 track car
Old 06-03-2012, 07:12 PM
"front of the a arm bolts at the bottom of the skid plate" i assume this is in center of car, not slanted to one side, and skid plate is behind the rack?
Old 06-05-2012, 08:35 AM
mikeesik's Avatar
I've been under my 88 more times than any girl friend I've had.
This is the way I've always lifted the car and there were no problems what so-ever.
Formerly from ratslist.
AMG E 55..2002.
Lotus Esprit SE. 1990
Old 06-05-2012, 02:03 PM
Pete R's Avatar
no, just on the front of either the left or right a arm. (off center) If the rear is on stands it will lift even as if jacking in the center
Neon SRT4 track car
Old 06-05-2012, 04:37 PM
okay, thanks, i will look carefully at fronts this weekend. the backs make perfect sense and very logical.
Old 06-05-2012, 04:54 PM
jacking basics s4
just to close out this thread, i was able to jack up the car as instructed by forum using the rear jack point, and then i placed a jack under front jack point. then i used wood 2 by 4 on fron frame area, and basically tilted the car and lifted one side and placed jacks, then went to other side and did the same. put wood blocks under jack points and jackstands at four corners......it takes patience as it moves a bit when you jack up one side.....but after some adjusting....it sits nicely....
thanks all.
Old 07-02-2012, 06:21 AM
inventor
porken's Avatar
Or...
Old 07-02-2012, 11:03 AM
MPDano's Avatar
Here's how to do it in Picture form.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 07-02-2012, 11:20 AM
SanDiego928's Avatar
Porken lift. So nice. Dano jack. So funny.
Old 07-02-2012, 12:46 PM
Kool
AirtekHVAC's Avatar
LoL..."Dano-Jack"
Ron
1978 5sp (#30) project-Wreckscue, 1979 5sp Euro Project
1982 5sp resto project, 1985 Auto S3
1984 Parts car (the fire car) 1987 s4 (parts, or maybe project)
(Yes, I now have 4 project Sharks)
Old 07-02-2012, 02:17 PM
MPDano's Avatar
You can protect your car with:
Old 07-02-2012, 02:25 PM
Kool
AirtekHVAC's Avatar
**snicker**
Ron
Old 07-03-2012, 08:36 AM
