Temp II replacement
My 84 has been running rich since I got it in January. From reading the forums, one of the possible culprits is the Temp II sensor. I finally got around to testing it with a multimeter. Measured resistance from each pin to ground and the reading for each indicated open circuit. I've placed an order for a new sensor.
Any gotchas I should know about when replacing the sensor. or is it as straightforward as it looks?
Hugo
Present: 1984 928S/Indischrot, 1994 968/Polar Silver
Past: 1979 911SC Targa/Petrol Blue
Old 06-17-2012, 11:17 AM
pretty straightforward, dont forget to replace the crush ring (900 123 101 30) that goes with it. waterbridge is lightly pressurized even when cold so have some towels handy (and a spare finger to plug the hole for minimum spillage).
My Car:
84' 928 S with Euro Mods - Quartz Gray Metallic (Quite the project!)
Old 06-17-2012, 05:22 PM
Turns out the Temp-II sensor is fine. The test procedure I found in another post is for LH-Jetronic systems where the sensor has two outputs. The Temp-II for L-Jetronic systems is tested my measuring resistance across the terminals.
Back to the drawing board....
Hugo
Old 06-25-2012, 05:13 PM
o2 sensor and AFM come to mind. otherwise potentially faulty L-jet. rich at idle, semi throttle or full throttle?
My Car:
Old 06-26-2012, 08:58 AM
I notice the telltale smell of a rich running engine when I pull into the garage after a drive. I don't think it's a major problem considering there's no black soot coating the area around the exhaust outlets like I've seen on one thread here.
In terms of possible symptoms, the only other thing I have is a slightly lumpy idle.
Next step is testing the O2 sensor. I hope the thing isn't rust welded in place.
Hugo
Old 06-26-2012, 12:12 PM
You tested the Temp II sensor correctly. The two prong on an 85 is tested the same way. pin-ground. The Temp II sensor has two prongs on the 85 because the sensor sends one temp signal to the LH computer and one signal to the EZK computer. The 85 also has another temp sensor that goes to the dash gauge. If your temp II sensor is open circuit from pin to ground it is bad.
According to the WSM an infinite ohm reading(open circuit) means a excessively rich mixture, engine will not run warm and can not be started. For a short circuit(0 ohms) mixture too lean, no pickup in cold state.
Hope this helps.
69 911 2.3Ez
85 928S
Old 06-26-2012, 05:28 PM
The 84 is L-Jet, not LH, so the Temp II is definitely tested differently - i.e. resistance is measured across the two pins, not each pin to ground.
I started suspecting as such when I tested the new Temp II that I purchased and it was open circuit from each pin to ground but had proper resistance at various temperatures when measuring acorss the two pins.
Hugo
Old 06-26-2012, 06:18 PM
harborman's Avatar
Mine ran rich when I got the car. I ran about two bottles of Techron in it and after a short time it cleared up and runs fine now. Something simple to try anyway.
1986 928S
32 valve engine
All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires.
Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster
Old 06-27-2012, 06:17 AM
I'm already on the first bottle of Techron so we'll see how it goes.
Hugo
Old 06-27-2012, 06:52 PM
