82 928 euro atm/lsd
trans wont down shift from 2nd to 1st
car shifts fine but when slowing down and shifting from 2nd to first it wont engage unless im at a full stop. wont even engage at a slow roll less than 5 mph.
never worked on 5sp before but not afraid to get my hands dirty. im thinking maybe an adj on the clutch rod or is there something silly im missing.
1979 928 5 speed 90k
Old 09-03-2012, 08:23 AM
MPDano's Avatar
Sounds like a pressure plate to me.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 09-03-2012, 03:35 PM
Pete R's Avatar
Mines always been like that.
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold)
Neon SRT4 track car
Old 09-03-2012, 04:17 PM
82 928 euro atm/lsd
is there an adj i can make to the pedal because right now i have to press the pedal all the way down to shift gears. im 5.3 with short legs (lol) can i adj the pedal to engauge the clutch sooner.
Old 09-03-2012, 05:11 PM
Pete R's Avatar
There may be a height adjustment on pedal but you will still need the same amount of movement to disengage. It's a self adjusting hydraulic clutch. If your clutch isn't disengaging until the very bottom it could be a couple of things. The clutch could have air in it or the intermediate plate could be out of adjustment causing the discs to drag.
Neon SRT4 track car
Old 09-03-2012, 06:29 PM
1979 5sp 928 project
Pete,
How do you adjust the intermediate plate? And, If I bleed the clutch master to purge it of any air, where do I fill it up? Does it run off of the brake fluid?
I know I jumped into the post, but my shifting problems might be this as well.
Thanks for your help
1979 928 5sp project
1984 928S 5sp black on black
Old 09-04-2012, 07:57 PM
82 928 euro atm/lsd
When I bled my slave cylinder I filled it from the clutch master on the drivers side. If you don't have a manual for the car go to the website sharkskin Porsche there is a ton of info
Old 09-04-2012, 08:30 PM
