Where would one send off injectors for cleaning and how much would that roughly cost for a US version 16V "S"?
Old 08-19-2012, 09:05 PM
Dean_Fuller's Avatar
Google "Witch Hunter"....IIRC set of 8 is well less than $100.
1980 AUTO Synergy Green Metallic / Black & Grey ( my son's)
1989 Auto Slate Grey Metallic / Cashmere & Black (mine)
1982 5-speed White / Black sport seats ( brothers )
Old 08-20-2012, 07:10 AM
Thanks Dean.
Old 08-20-2012, 12:48 PM
MPDano's Avatar
Complete Cleaning & Flow Testing of most gasoline injectors for only $21 per injector.
Includes before and after test data.
So, a little over $160 plus shipping. Well worth it too. See my $900 Porsche thread to see the before and after. They do a lot of work on them for $21.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 08-20-2012, 01:39 PM
Dadddio's Avatar
Yes!!!!
Got the fuel tank cleaned and reinstalled.
Not that bad.
doing fuel lines now.
I'm having trouble getting the fuel rails off.
I've got the ign. wires out of the way, the 2 bolts out that hold it down.
Can't get the injectors to come out.
Is there a trick, or is it just that tight?
Old 08-25-2012, 10:31 AM
stepson's Avatar
Tight baby!
John Curry (Drift King) 928OC member
Grand Prix White 1994 GTS AT (The GTS)
Black 1989 GT (The GT) and Cobalt Blue 1989 S4 AT (The Blue Car) 1986 Euro AT
Indishrot 1984 Euro S AT (The Stepson) and Black Metallic 1984 Euro S 5 speed (The Schwartz)
Old 08-26-2012, 08:30 PM
Dadddio's Avatar
O.k. been busy.
Did the fuel tank and fuel lines.
Cut the air pump belt.(won't need it)
Going to do a WP/TB.
Coolant looks goo, no oil.
Belt looks really good.
Replacing anyway.
But look at the water pump, looks brand new.
only got 1,000 miles on it.
Is there any way to check it?
Looks OEM. part# 928 106 122
Sure is a lot of oil on this engine. Valve covers????
See anything you think may need attention, let me know.
Keeping busy on it,.
D*** there's a lot of oil!!!!!
Old 09-02-2012, 03:31 PM
Dadddio's Avatar
forgot one...
Old 09-02-2012, 04:52 PM
Porsche newbie
Niles's Avatar
When you do the timing belt, you want the crank at 45 degrees. This allows the cams to turn without interference. You will also want the flywheel locking tool to keep it there. The one distributor rotor is showing wear. I would replace both and the distributor caps.
87 928 S4 Exported for Japan
Old 09-03-2012, 07:10 AM
Petie3rd
Mrmerlin's Avatar
you also have an aluminum oil pump gear it could be swapped out for the new steel version if you do swap then remove the 1mm spacer behind the gear.
also consider replacing the oil pump O ring use Dow corning on the O ring and STP oil to prime the gears and the 2 dots face the engine when installing 1 dot on the drive gear and 1 dot on the outer gear
Old 09-03-2012, 07:22 AM
