CIS K-jet, how to make leaner mixture
Hello,
Help needed. Thanks for advice in advance. I think my car runs too rich.
1 .My car is 1983 CIS K-jet 928. Simple question: when I turn the mixture screw clockwise, does the car run on leaner.
2. Has someone experience how much 1/4 turn clockwise approximately has effect on aer-to-fuel ratio?
Regards
Ismo
Old 09-15-2012, 07:41 AM
Network Native
Danglerb's Avatar
I'm not sure guessing on air fuel ratio is a good idea. Have you pulled your plugs and checked the color?
Old 09-16-2012, 08:45 PM
Hello,
Yes I know it is not definitely good idea just to adjust without knowledge. But in this case it not happening. The smell of exhaust is rich, meaning I you can smell the "too much gasoline" odour in the exhaust. On a manual system it would be like using the choke too long.
Anyways. Roughly how much is 1/4 turn clockwise. Does anybody have even some experience on the subject? Even the direction: is 1/4 turn too much for AFR adjustment?
Backround: The car is 1983 Euro CIS. It runs and starts quite well here in cold Finland.
Old 09-17-2012, 01:02 AM
rjm65's Avatar
Clockwise = richer
Counterclockwise = leaner
Adjust mixture counter-clockwise until it misses (note position of allen wrench) then turn clockwise until it misses (note position again). Now set the mixture between those two points.
Raymond
1979 928 5 spd
Old 09-17-2012, 02:04 AM
Thank you very much!
Old 09-17-2012, 02:47 AM
A.J.
tychain99's Avatar
no manual adjustments for the K - J? I notice my cars smells like it is running a little rich also..
1980 auto- cashmere beige
1984 auto- black on black
Old 09-17-2012, 04:54 AM
MPDano's Avatar
A K-Jet will run richer than normal at idle for sure. I run an A/F Wideband Gauge so I know exactly my mixture. It's at 2500-3000 rpms is where it will run at 14.7, it runs around 13.1-5 at idle.
Use rjm65's guidance and he actually got mine started using the same advice.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 09-17-2012, 05:27 AM
A.J.
tychain99's Avatar
not gonna lie, I do not even know the difference between the two.
Old 09-17-2012, 12:18 PM
Kool
AirtekHVAC's Avatar
This is from a bike site, but informative, and simple...
Randakk's Cycle Shakk - Honda GL1000 Specialist: GL1000 GL1100 Tech Tip#72
Ron
1978 5sp (#30) project-Wreckscue, 1979 5sp Euro Project
1982 5sp resto project, 1985 Auto S3
1984 Parts car (the fire car) 1987 s4 (parts, or maybe project)
(Yes, I now have 4 project Sharks)
Old 09-17-2012, 12:40 PM
I would adjust it as rmj65 described as the frequency valve can only make small adjustments to the control pressure based upon the O2 sensor signal.
Dennis
Dennis
Old 09-18-2012, 05:57 AM
Network Native
Danglerb's Avatar
Unless some weird thing was done in federalizing a Euro CIS 928 doesn't have a O2 sensor or control system.
Old 09-18-2012, 11:17 AM
Dan,
1980 and later cars with CIS required the O2 sensor and controls to meet US emissions standards. Some shops may have taken shortcuts and not converted to the KE system. Irregardless, the A/F ratio adjustment is the same on both.
Dennis
Old 09-18-2012, 11:46 AM
