1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold) Neon SRT4 track car |
928: Serial Enabler
Good information here, thanks!
Am watching for the Carerra III's. They look perfect on your white car. Last edited by Landseer; 11-04-2012 at 10:29 PM.. |
You make pulling the Tranny easy. Closely watching your project.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior 1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD** ![]() |
Agreed. Great wrenching!
Matt Mariani @the_r_institute Authorized Retailer FIKSE Wheels Mod Italian Wheels Maxilite classic wheels |
928: Serial Enabler
The transmission removal is pretty straightforward. I've done a series of these.
The front suspension swap is a time consuming endeavor. |
928: Serial Enabler
Moving into reassembly phase.
Still need to find some bilstein specific adjuster collars, as shock install is pretty much first on the list. While waiting. New bearings for front hub ![]() ![]() |
Recovering dismantler
Chris, nice work, I wish I had taken the time to photo shoot all my work ( like Leo - Dano - does) . Maybe the next major task i undertake i will, seems like all mine are electrical troubleshooting or harness rebuilds, or its been done before, , and i get so preoccupied in the task i forget the camera.
Neil 2009 Mini Cooper 2004 Mercedes CLK500 2024 Subaru Outback Touring XT 2020 Entegra Coach |
Kool
I usually get too greasy to want to touch the camera...then I regret it afterwards....then I repeat the cycle the next project..
Ron 1978 5sp (#30) project-Wreckscue, 1979 5sp Euro Project 1982 5sp resto project, 1985 Auto S3 1984 Parts car (the fire car) 1987 s4 (parts, or maybe project) (Yes, I now have 4 project Sharks) |
928: Serial Enabler
Inner tie rods are shorter for S4.
Could probably shorten the S ones, but they have countless miles on them. I bought a set of S4 inner/outers to swap. Tried to remove them in-situ. Too tight, risky, could damage rack. Removed rack to manage this swap on bench using vice to contain the counterhold wrench. Also, stabilizer bar links are longer for S4. Those get swapped too. Also, stabilizer bar itself is different for S4 Diameter same, but ends have a different angle. So it gets swapped along with the links on each end. (Not sure if the S swaybar and S links would fit instead of the S4 set / they might also) WSM does a good job of pointing out differences between S and 86.5 (they call it 86) I'm calling it S4. Nothing but carnage so far tonight. Wife is pissed at the ever-expanding mess. ![]() ![]() ![]() ![]() Last edited by Landseer; 11-20-2012 at 01:45 AM.. |
928: Serial Enabler
Looking ahead, Antilock is going to get interesting.
Rear axle counter gears are different. Front hubs with counter gears are different Sensors are different Bias valve on Euro is 33 bar, which I'll retain over the 86.5 unit which is 18 bar. Pumps are the same. Harnesses are different from each wheel to brain. Brain is different. Not sure about Brain plug side of harness and the wires leading to the CE panel. CE panel has a position change for the panel-mount relay and different fusing. Last part will be a challenge at the CE panel and leading to the brain. Last edited by Landseer; 11-12-2012 at 07:06 PM.. |
OB Wan
Chris,
Great documentation! You have really taken my old Chewy to the next level.
Jim Doerr - 928 Classics http://928classics.com '77 ('78), Preproduction Press Car, 9288100016, 'Number Six' '78 US, 5 speed, #225 '78 Euro/RoW, 5 speed, #1075 '79 US, 5 speed, #0954 |
Nice work! and nice press, where did you buy?
Looks like my Harbor Freight one.
lol, I have the one that is an "A" frame...for what it cost for a shop to press a couple bearings you can buy a whole harbor freight one.
928: Serial Enabler
Exactly.
Except mine isn't square. Needs a few bolt holes elongated, application of a square, and my neighbor's welding gear. I just bought replacement nuts for my front bilstein shocks. $95. Each. Those were expensive cuts I made. |
Petie3rd
Ouch on the Bil nuts
FWIW you should heat the hubs prior to installing the races races go into the freezer, install the small race first, then the large as it will usually fall out a press isnt necessary
^^^ Stan ^^^ 2019 BMW K1250 GS 2016 HD RK 1988 S4 Auto , Elfenbein Perlglanz, Pearl Gray 1982 5sp Met black and tan sport seats Last edited by Mrmerlin; 11-20-2012 at 05:17 PM.. |
+1 I've done it.. very effective. Since my wife wouldn't let me use the oven, I bought a single burner hot plate at Wally Mart.. works great
928: Serial Enabler
I've been given this advice before about the bearing races.
Used my gas grill to preheat hubs. Took a phone call prior to install, hubs cooled. Will use that advice on the next set, along with freezer. Meanwhile, axle boot kits are on-the-way from Roger. Mark is sending new Bilstein adjusters. Suspension assy completion target is Thksgvg. Prior to that, some interior work and harness transplants. Last edited by Landseer; 11-20-2012 at 02:23 AM.. |
928: Serial Enabler
Yes, this used to be Jim Doerr's car!
Somewhere I've got a picture of him with it about 10 years ago. Some evidence of progress. Rack reinstalled with new tie rods. S4 Sway bar and links Rebuilt upper control arm Awaiting shock adjusters, then rest can be reassembled. Oh, and I have a set of front fender well liners from the 86.5. Might need to cleanup the wells and mount them later. ![]() The patient, anxious to run ![]() Gotta fix the torn rear boots that came on the 86.5 axles. A few timing belts, too, for future project work ![]() 86.5 axles and hubs with some spacers. Need to remove the big axle nuts today. Am going to try to get the rotors resurfaced. Just enough wear and pitting to be worth trying that, but not worn too badly. ![]() Antilock brains. 86.5 vs 84. Same case, same connector (not sure about the pin outs yet). Different programming. ![]() ![]() ![]() Last edited by Landseer; 11-20-2012 at 02:24 AM.. |
928: Serial Enabler
Throwback shot. Lifted from a Polaroid
Same patient 84 Euro car dubbed "chewy" for his odd in-dash sounds. The formative years of resident 928 historian and owner of Press Release 928's #1 and #6. Looks like a grad student ready to hop into a TR3 and light a pipe on the way to class, skirted college coeds all around. (Video from J Geils "Centerfold" comes to mind for some reason.) http://www.youtube.com/watch?v=BqDjMZKf-wg ![]() Last edited by Landseer; 11-20-2012 at 02:58 AM.. |
