OB Wan
Well done, Landseer. Long time is right!
Jim Doerr - 928 Classics http://928classics.com '77 ('78), Preproduction Press Car, 9288100016, 'Number Six' '78 US, 5 speed, #225 '78 Euro/RoW, 5 speed, #1075 '79 US, 5 speed, #0954 |
928: Serial Enabler
More to come.
Need to document the front Eibach install. And finish ABS And make sure brakes are all working right --- hoping all pistons are moving freely. (normally I rebuild S calipers before install, but these S4 brakes are complex and kits have questionable availability) And do a real good summary. No more driving until Eibachs arrive + alignment. Proving that the 155K mile G28-10 box shifts essentially like new helps my psyche on this project. Time to savor that. Last edited by Landseer; 12-02-2012 at 05:52 PM.. |
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior 1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD** ![]() |
GAFB
Instead, I carefully examined each caliper. The dust boots were intact, the pad wear was perfectly even, and the donor car was a low mile example. Roger suggested it may be possible to order seals and dust boots directly from Brembo to avoid the Porsche tax, but I haven't checked into that yet as my calipers have plenty of miles left before needing a rebuild.
Several BMWs |
Matt Mariani @the_r_institute Authorized Retailer FIKSE Wheels Mod Italian Wheels Maxilite classic wheels Last edited by The Fixer; 12-15-2012 at 11:33 AM.. |
928: Serial Enabler
Car needs to come back into garage.
Needs its ride height tweaked a tad. Can you say "Eibach"? Fronts are much shorter in length, but within the scope of the adjuster nuts. Right now, with the stock springs and Bilsteins, the adjuster nuts are bottomed out. Winding them to compress the springs will lift the car further, hence the need for these new springs. The Bilsteins really add lift, kind of like air shocks that you can't get the air out of. Many thanks to Chuck in TX for selling them reasonably. And Jim Doerr for calling me on the phone the minute they hit rennlist for sale. ![]() Last edited by Landseer; 12-20-2012 at 02:36 AM.. |
928 Junkie
Chris, did you say that you would not suggest removing the rear end and transmission as one unit? I am trying to formulate a plan of attack for the 79.
Brian Phillips 1979 928 , 5-speed, cork interior 1982 Euro S 5-speed project 1985 928S, auto(sold)1978 Euro 5-speed (found another home)1983 928 s 5 sp short shifter black/black (sold)1982 928 auto (sold) |
928: Serial Enabler
Chain trans up to the sway bar.
Drop cross member ( with springs and shocks if you are not replacing them) Remove trans and TT together as unit. We can speak about it if you want. |
928 Junkie
Thanks man, pm sent
928: Serial Enabler
Here's an intermediate picture from the last time Jim and I had Chewy's transmission out, back in Virginia, summer of 2010 I think.
Key here is getting car high enough so the shocks clear gas tank. If you intend to remove shocks from carrier, I'd suggest doing it while carrier is still mounted to car for stability. But if you do that, put the lower mounting pins without shocks/springs, back through the suspension so it doesn't flop around. The reason we had to remove the trans that time was it had gotten stuck in between gears during a minor collision (can happen). Trans is still up in there, chained up. ![]() While we are at it, here's a contrast of (earlier) transaxles --- showing without vs with LSD. LSD is on right. ![]() Last edited by Landseer; 12-20-2012 at 02:50 AM.. |
928: Serial Enabler
Back on track ( its a blog, blogs have ramble )
Eichbach swapped in, replacing the 3 green stripe original, right side. Didn't separate any the ball joints or steering tie rod from spindle. Left spindle, rotor, caliper intact. Used a trans jack to hold it up. Took loose the lower ball joint mount from the lower control arm (removed camber / caster eccentrics) Removed lower control arm. Spring and shock could be then be removed as a unit. Spring compressors used to swap springs. During reassembly, removed the rubber S air guide from beneath control arm. Used jack to load the a-arms, then tightened the mounting bolts for lower arm. Probably something you guys could do in your sleep. I had to think thru it. ![]() Trans Jack lifting under lug nuts. Chain used to keep jack from kicking out. ![]() Lower arm removed ![]() Lower arm ![]() This side installed. Will loosen lowers and retorque later, to promote settling, when car is on ground. ![]() Last edited by Landseer; 12-24-2012 at 03:33 AM.. |
I don't think any of us could do what you're accomplishing in our sleep. Suspension work is difficult. If you lived close Landseer i'd help you paint it when you're done. That you could do half asleep with a little help.
Matt Mariani @the_r_institute Authorized Retailer FIKSE Wheels Mod Italian Wheels Maxilite classic wheels |
The Eibach's settle really quick. Mine settle in a few hundred feet as opposed to the stock ones which took forever
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold) Neon SRT4 track car |
Network Native
I am super twitchy with suspension work, no chains, no hoping this or that does what I expect, just pure paranoia.
928: Serial Enabler
That's a good point.
Doesn't matter how solid it sits on 4 hefty jackstands. Add a jack --- it can get dynamic and dangerous. In the pics above, the weight carried by the transmission jack is limited to the weight of the free pivoting rotor/spindle/caliper. I could hold it up by hand, but ran out of hands to remove the spring and shock combo. But when I loaded the suspension with the yellow jack, the front right was off the jackstand and the left was fixing to follow. None of that was really necessary, I just lazy trying to see where the spring height was going to end up, and it honestly didn't answer that. Be safe. Last edited by Landseer; 12-25-2012 at 05:45 AM.. |
Network Native
I think I used a wire coat hanger fed up through one of the three bolts for the shock tower mount.
928: Serial Enabler
Car is on the ground. Its looking much better. Haven't driven it to settle the rest of the way.
Right now I can get two fingers between bottom of fender lip and top of tire on driver's side, a tad more on passenger side. I flipped the Bilstein adjuster nuts upside down to gain about 10 mm of downward adjustment of nut, and they are bottomed right now. Rounded extended sleeve is pointing down, wide part of nut is up contacting the sleeve perch. WSM shows opposite. Spring perch seats well either way. Is it everybody's understanding is that winding the nuts upwards will raise the car? It should settle a bit more, though word is the eibachs settle less. Originally it was 4+ fingers, lots of space. Am curious if it will settle further and how far. Last edited by Landseer; 01-04-2013 at 01:56 AM.. |
928: Serial Enabler
Picture.
Fender looks a bit higher off tire than I expected it would. On wife's car, stock, the fender is just at or below the tire ![]() Last edited by Landseer; 01-05-2013 at 11:27 AM.. |
Kool
Sits a tad high, but looks good.....
Ron 1978 5sp (#30) project-Wreckscue, 1979 5sp Euro Project 1982 5sp resto project, 1985 Auto S3 1984 Parts car (the fire car) 1987 s4 (parts, or maybe project) (Yes, I now have 4 project Sharks) |
928: Serial Enabler
Here we are.
Drove for a while, settled a bit. Got one finger in, and that was tight. Will measure and adjust ride height, then hire-out an alignment. Next will be rejuevenation of antilock brakes. Gotta clean, repack, reboot and reinstall the correct rear axles (86.5). Maybe someday I'll save enough for a set of carrera III wheels. ![]() Red one sits a bit lower, but it has worn shocks and softest version of springs. That one is the next patient. Gets red koni, plus needs to have a full electrical polish job, and a TB. Wife has put 35k miles on it since 2008 rescue. ![]() Last edited by Landseer; 01-05-2013 at 11:29 AM.. |
