-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/porsche-928-technical-forum/)
-   -   Did anyone tinker with their 928 today? (http://forums.pelicanparts.com/porsche-928-technical-forum/748737-did-anyone-tinker-their-928-today.html)
Fixer 05-07-2013 05:56 PM
I searched for and didn't find so thought we could use one of these threads..
I drained my power steering fluid and refilled with Dexron ATF, cleaned the res and cap real well and replaced the seal. The cap dip had fallen off and was at the bottom of the res. Very clean and no longer losing fluid through cap, Looks nice.
Then took off steering wheel & greased horn contact and went to work.
Took about 15 minutes. Always do something before work lately I have been driving it a lot. running great:)
77tony 05-07-2013 06:02 PM
Installed a rebuilt steering rack and new steel balljoints on the 80. Fixed the upper door/window trim on the 94. T
riber.bentsen 05-07-2013 11:10 PM
Replaced the pull-wire for the hood release, as well as the backing to the handle in the cabin.
Replaced (well, put in place, since the ones that were there had fallen of by themselves) the aluminum shields that direct airflow from the ducts in the bumper to the front brakes :)
Today: CV-axle boots :( Those center-nuts are crazy-tight!!!
http://forums.pelicanparts.com/uploa...1367993161.jpg
Last week I did some other stuff, pics should be self explanatory:
http://forums.pelicanparts.com/uploa...1367993280.jpg
http://forums.pelicanparts.com/uploa...1367993322.jpg
http://forums.pelicanparts.com/uploa...1367993354.jpg
Fixer 05-08-2013 05:01 AM
Awesome T and Riber! I will try an take photos FNO, hope the rest also take pics to 'show your work'SmileWavy
AirtekHVAC 05-08-2013 03:45 PM
Epoxied the crack in my fuel strainer hub Sunday, let sit and then dremled it smooth yesterday, replaced the strainer, filled tank.... No leak yet...we will see....
http://forums.pelicanparts.com/uploa...1368053115.jpg
whatudrivin 05-08-2013 04:22 PM
Got my tank back from being cleaned late last week. Been too busy to get the correct size fuel hoses to put it back on. Just need vacuum hoses to get everything put back together. I think I can try to start afterwards. =)
Crumpler 05-08-2013 05:02 PM
It seems like I can never get enough light under my hood when I'm working, so I scratched together some canned lights and lumber that was left over from the basement. Now it's like an operating table!
I have not decided if it's pure genius or I'm WT.
http://forums.pelicanparts.com/uploa...1368057403.jpg
http://forums.pelicanparts.com/uploa...1368057469.jpg
http://forums.pelicanparts.com/uploa...1368057641.jpg
Fixer 05-08-2013 09:17 PM
Nice operating table Crumpler and nice 928, motor looks spotless. How did you get that nickname, accidents?
Ron and Brad hope your gas issues are solved!;)
This will be a great thread, motivates..going to clean motor before work tomorrow to prep for my electric fan upgrade.
Matt
Crumpler 05-09-2013 07:30 AM
Thanks Fixer. Your 83 is quite sharp.
I will try and get you more info on fan specs. tonight on the other thread.
No accidents in history but I tend to create collateral damage when working on car.;)
Fixer 05-10-2013 03:06 PM
Thanks Dave? Crumpler. I got the e fan in mail and it is installed. removed the AC con fan (wasn't working) and set it up to push air through (1500 cfm, 20 amp current draw) once through the AC coil cfm should be 1300, thermostat works well (probe type) happy to have no air pump and now sans the fan belt. saved 8 pounds O.aA.. Nice product for the price, will test all weekend and update you all.
Have a great night!
http://forums.pelicanparts.com/uploa...1368223545.jpg
http://forums.pelicanparts.com/uploa...1368223570.jpg
NOTE: This fan set up was changed to PULL and worked much better. It has been fine in the 90 degree heat.
AirtekHVAC 05-12-2013 06:08 AM
I got her running, again...no fuel leak yet. Prepping for brake lines, clutch line, and blue hose next. The brake line fittings are wicked rusty. I have been soaking them in Kroil every day....
SanDiego928 05-12-2013 10:49 AM
Good work you guys!! Had my first battery drain issue in 3 years. Jumped it drove about 100 miles. Checked battery and charging. Seems okay. I win today.
bowserdog1 05-12-2013 11:50 AM
Spent the past 3 days detailing the shark. Clay bar, scratch remover, 3 layers of Zaino polish and 2 layers of Zaino wax. Also put on leather conditioner and rubber rejuvenator. The car is very shiny now. Tomorrow I'll take it out for some good pictures.
chitown944 05-12-2013 01:07 PM
Performed the tail light harness mod. Worked great but taillamp dummy light stays on. Why is that.
Mrmerlin 05-12-2013 05:16 PM
^^^ probably a bad side marker bulb,
or the connector for it is dirty,
check along the rear edge of the floor of the hatch for the side marker light connectors,
they are 2 pin
chitown944 05-12-2013 05:22 PM
Now that u mention that...my drivers rear sidemarker doesnt work...replaced with new bulb and also checked fuses same result...ill peel carpet up and check that connector
por917 05-12-2013 05:38 PM
Changed engine oil and filter, changed autotrans filter need to pick up fluid, Check diff fluid for level.
Fixer 05-12-2013 08:24 PM
Cleaned front of motor, prep for TB replacement, (i can't get my pretty hands dirty) replaced my plugs, looked closely at plug wires, they look good and operate fine but are very old (Beru).
Tomorrow Camshaft drive belt, excited :)
SanDiego928 05-13-2013 05:39 PM
Found a new rear wiper blade in garage. Installed it. Woohoo. Checked out engine bay. Made a list.
Fixer 05-13-2013 08:48 PM
Too much, too little drivingSmileWavy
