dtw dtw is offline
GAFB
Bulb check unit causes tail light failure?
My mechanic and I have been starting to go through some electrical issues. All my exterior lights have been working perfectly, but my bulb check unit has been throwing idiot lights for tail lights and brake lights (both of which work(ed) perfectly). He opened up the unit and found a failed solder joint, which he fixed. That caused the tail light warning to go out. However, when I picked up the car, I had no tail lights (again, everything was working fine before messing with the bulb check unit).
My question is this - can a bad bulb check unit cause the tail lights to actually stop working? Or is this a coincidence, and there's something else at work. Yes, the fuse tested good and the bulbs are brand new.
As a side note - does anyone have a tested good bulb check unit for an '85-'86 S3?
Several BMWs
Old 05-15-2013, 08:52 AM
Recovering dismantler
neil30076's Avatar
Bad bulb check cannot cause brake lights not to work, more likely bad ground under rear passenger side qtr panel, or bad brake switch ( which is common). Does the light go out if you press the ! button?
Where in raleigh are you, i'm south in apex.
Neil
Neil
2009 Mini Cooper
2004 Mercedes CLK500
2024 Subaru Outback Touring XT
2020 Entegra Coach
Old 05-15-2013, 09:31 AM
dtw dtw is offline
GAFB
Neil
Not brake lights, tail lights. Brake lights are working fine.
Idiot light in pod does not extinguish when I push the ! button, no. But the ! does stop glowing red when I push it (as I do every single time I fire the car up ).
Several BMWs
Old 05-15-2013, 10:02 AM
Petie3rd
Mrmerlin's Avatar
check the fuses
Old 05-15-2013, 10:24 AM
dtw dtw is offline
GAFB
Originally Posted by Mrmerlin View Post
check the fuses
They're fine as stated in the OP.
Several BMWs
Old 05-15-2013, 11:12 AM
neil30076's Avatar
Sorry, my bad, The tail lights, front running lights and side markers are called the clearance lights in the wiring diagrams. I assume that is what you are referring to and they are all out? You say fuses 40 and 41 are ok. If only the back is out check for 12v at the lamp test module on pin 5 and out from the lamp check unit connector pin 3 to the rear lights. And yes, a bad check module can cause the back clearance lights to fail.
Neil
2009 Mini Cooper
2020 Entegra Coach
Old 05-15-2013, 12:17 PM
dtw dtw is offline
GAFB
Neil, thanks. Yes - 40/41 are good, only the back tail lights/side markers are out. We'll try what you mentioned.
Several BMWs
Old 05-15-2013, 01:23 PM
