Where is fuse box? With relays?
On my 1984 928 where is fuse box located? It also has relays in it as well,,
Old 05-27-2013, 11:57 AM
928: Serial Enabler
Behind a flip-up wooden hatch at passenger feet. On interior firewall.
Be careful what you do inside there. Need wiring diagrams to troublshoot.
Post really good overall pictures and a set of closeups and we can give input.
Include closeups of the wiring coming out of the plugs along bottom row.
Extremely useful in diagnosis.
Will need to remove the upper and lower wooden covers to get good pictures.
Old 05-27-2013, 12:02 PM
Crazy Germans. Lol
Pull the carpet from the passenger footwell. You will see the black plywood board at the front of the footwell under the shelf. Pul that up and it will swing up. Theres the fuse panel. Check MPDano's common fixes for cleaning the fuse panel and checking grounds.
1983 928s 5spd
Old 05-27-2013, 12:03 PM
928: Serial Enabler
Damn, look at the response times will ya. All over it!
Fuses and grounds, yes. But be sure to go through the wires on the plugs with a finetoothed comb.
Amazing as telltales of havic in the electrical system that you might not realize otherwise for a while.
Old 05-27-2013, 01:47 PM
whats mpdanos
Old 05-28-2013, 09:33 AM
Kool
AirtekHVAC's Avatar
One of the Gurus here. He started the "common fixes" thread...its at the top of the forums topic list.
Ron
1978 5sp (#30) project-Wreckscue, 1979 5sp Euro Project
1982 5sp resto project, 1985 Auto S3
1984 Parts car (the fire car) 1987 s4 (parts, or maybe project)
(Yes, I now have 4 project Sharks)
Old 05-28-2013, 02:38 PM
all fixed ,,,,it all came down to the battery was junk!!!!!!!
Old 05-28-2013, 05:27 PM
Network Native
Danglerb's Avatar
928's go through batteries like pancakes. Almost all 928's have some kind of drain, current draw long after turning off the key, and full discharge or even deep discharge ruins most batteries quickly. After years of dealing with it, I put disconnect switches on both of mine.
Old 05-28-2013, 07:57 PM
harborman's Avatar
I got a good deal at Walmart on my battery. It's been two years since and it seems fine. If a battery last 4 years, time to replace it anyway. I don't disconnect it and it starts fine after sitting a month sometimes. One thing you might want to do is replace the braided ground strap on the battery. Mine looked fine but went bad inside the crimped end.
1986 928S
32 valve engine
All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires.
Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster
Old 05-29-2013, 05:54 AM
