rear main seal help
I got call from my brother who is been tuning my 84 928, 5 speed manual tranny, he said the rear main seal is leaking baddly?
.HOW DIFFICULT IS TO FIX IT
any help detail best way to task , is this common fail in 928
Old 06-22-2013, 05:00 PM
Petie3rd
Mrmerlin's Avatar
is he sure its the RMS,
usually its the rear cam tower gaskets,
Roger sells new silicone gaskets.
I would replace these gaskets before you do a RMS
Old 06-22-2013, 05:43 PM
Network Native
Danglerb's Avatar
Main seal would need to drop the clutch, not for the faint of heart to mess with a working clutch.
Old 06-22-2013, 09:10 PM
Automotive Necromancer
SolReaver's Avatar
Send a message via Skype™ to SolReaver
rms
A good deal of work. Lots of WYAIT and many hours. Essentially you are doing a clutch job. If the RMS is leaking the clutch may be compromised as well.
There may be nothing quite as expensive as a cheap Porsche: Ruby Red 84 928S : White 87 924s 2.5L NA (Blinky) M44/07-43H10676 spoiler delete - 046/2B - Belts 9/12, Clutch and OC seals 8/08 andd Red 94 Del Sol: Please put your Make, Model and Year in Sig. Try not to break more than you fix.
Old 06-22-2013, 09:28 PM
i've got a 83 project car with leaking rear cam gasket seals. How many hours is it to replace.
Old 07-02-2013, 05:14 PM
Petie3rd
Mrmerlin's Avatar
to replace the rear cam seals takes about 30 mins a side,
and is easier to clean the surfaces from the bottom reaching up, Roger sells new silicone seals to replace the cork gaskets
Old 07-02-2013, 08:53 PM
