rear main seal help
I got call from my brother who is been tuning my 84 928, 5 speed manual tranny, he said the rear main seal is leaking baddly?
.HOW DIFFICULT IS TO FIX IT any help detail best way to task , is this common fail in 928 |
Petie3rd
is he sure its the RMS,
usually its the rear cam tower gaskets, Roger sells new silicone gaskets. I would replace these gaskets before you do a RMS
^^^ Stan ^^^ 2019 BMW K1250 GS 2016 HD RK 1988 S4 Auto , Elfenbein Perlglanz, Pearl Gray 1982 5sp Met black and tan sport seats |
Network Native
Main seal would need to drop the clutch, not for the faint of heart to mess with a working clutch.
Automotive Necromancer
rms
A good deal of work. Lots of WYAIT and many hours. Essentially you are doing a clutch job. If the RMS is leaking the clutch may be compromised as well.
There may be nothing quite as expensive as a cheap Porsche: Ruby Red 84 928S : White 87 924s 2.5L NA (Blinky) M44/07-43H10676 spoiler delete - 046/2B - Belts 9/12, Clutch and OC seals 8/08 andd Red 94 Del Sol: Please put your Make, Model and Year in Sig. Try not to break more than you fix. |
i've got a 83 project car with leaking rear cam gasket seals. How many hours is it to replace.
Petie3rd
to replace the rear cam seals takes about 30 mins a side,
and is easier to clean the surfaces from the bottom reaching up, Roger sells new silicone seals to replace the cork gaskets
Thread Tools | |
Rate This Thread | |
