No right front turn signal????
On my 84 928s my right turn signal don't work in the front of the car at all. Works in the back on the right side but blinks real fast. I checked bulbs and look to be fine. Left side works like it should.. Any one ever have this issue? i would appreciate some help. Thanks
Petie3rd
jack up the RF and remove the front tire,
then the front block off plate, then inspect the wires, there should be a few connectors under the fender near the bumper and maybe one has come loose, also inspect the harness where it enters the wheel well under the headlamp, if the harness is binding at the metal harness clamp, it can be cut so check the harness with the lights up, check both sides for this condition. Also make sure that bulbs you have are the same front and back and side to side also check the side marker bulbs
^^^ Stan ^^^ 2019 BMW K1250 GS 2016 HD RK 1988 S4 Auto , Elfenbein Perlglanz, Pearl Gray 1982 5sp Met black and tan sport seats |
And.....along with what MrMerlin has posted, remove the bulb and clean the socket.
John Curry (Drift King) 928OC member Grand Prix White 1994 GTS AT (The GTS) Black 1989 GT (The GT) and Cobalt Blue 1989 S4 AT (The Blue Car) 1986 Euro AT Indishrot 1984 Euro S AT (The Stepson) and Black Metallic 1984 Euro S 5 speed (The Schwartz) |
Thanks guys i am gonna go try it rite now i will let u know how i make out
I think its a wire or a bulb ,,,cause u put hazard lights on and they all flash normal except that right front,,,what ya think but with out hazards on the right side rear works but flashes fast front dont work at all.
I put it up in the air checked the bulb and then checked wires, if i check the front turn signal wires well plugged in with the turn signal on both wires test as a ground i unplug the turn signal socket and the black and green stripe has power flashing to it, plug it back in they both test as a ground,,,any ideas any one maybe i need to replace the turn assembly or socket????
pull the bulb out and re-test which is grounded. this is something i noticed on my turn signal when i got my car back from the body shop, they put the wires on in reverse, causing the power to ground and blow my fuse every time. switched the wires and no more problems. one of the connectors seemed like it was already grounded. Worth a shot in your case.
My Car: 84' 928 S with Euro Mods - Quartz Gray Metallic (Quite the project!) |
i did that and the wires are color coded
I bet it's the turn signal stalk. You can drill out the rivets and clean all the contacts in there, but beware there are a lot of springs and balls. I actually couldn't put it back together and one of my friends did it for me. Works like a charm.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior 1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
