Overheating and Radiator Problems i think
The car overheats after 10 minutes and the koolant cap just blows off. there was a new water pump and timming belt. The radiator gets hot at the top but is normal temperature at the bottom. I have no clue what the problem is.
its a 1979
Old 10-25-2013, 06:22 AM
Reddog2's Avatar
More info would help.
Is this problem new - ie right after recent work on wp or coolant system?
Sounds like it could be air in system and if work was just done, thats the first place I would start.
86 928 Euro 5 sp Red/Blk
63 E-type, 63 Valiant
12 MB C63, 12 MB ML350
Old 10-25-2013, 07:11 AM
harborman's Avatar
Air in system, stuck thermostat, water pump defective, low coolant level, blockage in radiator, etc. I was going to say belt tension but the pump is driven off the timing belt.
1986 928S
32 valve engine
All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires.
Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster
Old 10-25-2013, 09:38 AM
Going out on a limb here and maybe the more experienced guys will correct me, but it sounds like the radiator needs to be replaced if it's original equipment.
Old 10-25-2013, 09:53 AM
dtw dtw is offline
GAFB
I had this happening after my intake refresh...I put the !$#^*ing thermostat in backwards. Flipped it and all was well. Sounds like you may have a bad thermostat.
Several BMWs
Old 10-25-2013, 10:11 AM
