Closed Thread
Safer than jack stands
If you do not have to work on the front end, here is an inexpensive way to lift your vehicle 8" off the ground, and much safer than jack stands. However, jack stands can still be used as a secondary safety placed under the lift points.
1986 928 automatic
Old 12-22-2013, 11:49 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #1 (permalink)
19psi's Avatar
I have large solid blocks of wood that size that I often use on my vehicles. Although I now have Porken Bars for the 928.
I'd recommend securing all those 4X4s together with multiple long screws. With enough sideways force (heavy duty wrenching under the car), I can see the possibility of it toppling like a Jenga tower. Plus add a wood ridge on one side of each set in case the car rolls. A ridge facing rear for one wheel and forward on the other.
George in Indiana
928 Weissach #153
Cayenne S
Old 12-22-2013, 04:48 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #2 (permalink)
^^^, if they are REALLY well secured together as one solid block, ok. if not, NO WAY!!
4 separate blocks are about as good as the high tech effort in the pic below!
it's your life, you get one shot at it!
(looks like he is welding up the fuel tank- this is obviously the "before" picture)
'82 928,2002 4.3 lexus quad cam VVTI V8,5 spd Auto.(at the front)BorgWarner 3.08/1 LSD-at the back-Weisach retained,Transaxle gone.Borla exhaust,XSchops Cayenne big brakes front ,968 front brakes rear.Mk4Supra m/s & servo. Alloy rad,1380kgs(3036 lbs(53%F/47%R))
Old 12-22-2013, 10:24 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #3 (permalink)
Network Native
Danglerb's Avatar
Looking at those blocks "safe" isn't my first thought.
Old 12-22-2013, 11:04 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #4 (permalink)
Petie3rd
Mrmerlin's Avatar
WARNING please do NOT follow the advice that has been posted in thread 1.
Use the the proper Jack stand supports for each corner of the car,
Also only use a proper floor jack.
WARNING that jack in the the picture should only be used as a last resort to change a tire.
The ideas posted are about the most unsafe vehicle support/ lifting that could be devised.
Old 12-23-2013, 02:12 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #5 (permalink)
Len 911's Avatar
Just delete this tread before someone gets hurt. I bet the neighbor is pissed now that their landscapeing is missing the timber.
Old 12-23-2013, 04:15 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #6 (permalink)
Pete R's Avatar
Fail
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold)
Neon SRT4 track car
Old 12-23-2013, 05:13 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #7 (permalink)
dtw dtw is offline
GAFB
It isn't April Fools day...this thread was a joke right?
Old 12-23-2013, 05:14 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #8 (permalink)
A Wrench
SeanR's Avatar
I sure hope so because all I see in that picture is a popped skull and a widow crying.
'88 Supercharged and lots of other fun stuff.
Old 12-23-2013, 06:23 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #9 (permalink)
Len 911's Avatar
He has a flashlight there to catch the car if it falls. I also see the can of lube to spay on his head to help slide his head out. This will help so the coroner wont have as many scratches to fill.
Old 12-23-2013, 06:50 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #10 (permalink)
928-Electrics Guy
Alan in AZ's Avatar
So many issues...
A stack of 2/10" screwed together with end stops would be much better (but as a backup safety method - not primary)
Two 4x4" aren't 8" either (a 4x4" is really a 3.5x3.5")
The jack stands shown look remarkably weedy - what are they rated at?
Not liking the wood there either.
If you need to support in the air for some time without a real lift - put decent ramps under the wheels (opposed) and/or use sturdy jack stands
Alan
1994 928 GTS Black/Black Manual
Old 12-23-2013, 08:07 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #11 (permalink)
MPDano's Avatar
Originally Posted by Alan in AZ View Post
If you need to support in the air for some time without a real lift - put decent ramps under the wheels.
Alan
If you use ramps, throw some old wheels under there as well. I am paranoid, I even put jack stands there as well.
Too many stories of cars falling down on their owners and not being found until hours later. With your chest compressed, you cannot scream for help.
Yes, this is a very bad example of "safe."
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 12-23-2013, 08:12 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #12 (permalink)
80 928
Hey! who took a picture of me doing a Redneck repair?
Old 12-23-2013, 08:57 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #13 (permalink)
Antsmands
antsmands's Avatar
Thumbs down
Originally Posted by danglerb View Post
looking at those blocks "safe" isn't my first thought.
agree!
1983S 5 Speed / Platinum Metallic / Dark Brown Interior / GE NightHawk LED Headlights / Super Bright LED / Flex-a-lite Cooling Fan / Dragon Gauges / Custom Auto Sounds Spare Tire Sub Woofer / H3R HalGuard Fire Bottle
Old 12-23-2013, 09:02 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #14 (permalink)
Porsche 928 Fanatic!
One good sideways shove, and that car would be on the ground - on your head.
It is a simple matter of weight re-distribution -
Jackstands take 3 square inches of downward force (top of jackstand) and spread it over 100 square inches (base of jackstand)
Those 4 pieces of lumber, if they are not bolted together, take 64 square inches of force (tire face on top) and reduce the base footprint (all on 1 piece of wood)
Not a bad backup IN CONJUNCTION WITH jackstands, but by itself? Extremely unsafe, bad idea.
Webmaster - www.GreatWhite928.com
250+ 928s for sale at all times!
Old 12-23-2013, 09:03 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #15 (permalink)
Linderpat's Avatar
insane. Another "cheap" way of doing something that isn't cheap at all, unless you don't value your life!
Ed
85 928 5 spd (guards red over tan)
07 Shelby GT500 6 spd (torch red over two tone black and red leather)
Old 12-23-2013, 09:37 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #16 (permalink)
Thanks. Yes, they are screwed together, horizontally and vertically. The rear wheels are off the ground.
Old 12-23-2013, 10:40 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #17 (permalink)
LOL....great pic. Thanks for sharing.
I have been out of body. You get more than one life. I died when I was 13, and was Sent back. You have been here in other lifetimes, many times previously to this life you are presently living. But it is your mind, and you can believe what you like.....lol....do not waste it on idle assumptions....
Old 12-23-2013, 10:43 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #18 (permalink)
Thanks for your concerns. No one is suggesting anyone follow anyone's advice. Actually no advice was given, except the advice you are giving.
Old 12-23-2013, 10:45 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #19 (permalink)
Pete R's Avatar
good thing, I'd hate to be taken out for an eternity with that jacking set up
Neon SRT4 track car
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #20 (permalink)
Closed Thread
