does this go Here?
I have pulled the Air plenum and throttle body off of my 84. When doing so I found a large nipple on the side of the throttle body with nothing attached to it. Underneath it I also found a short cap like piece that looks like it may have been attached to it. I have provided picture too. I know how we all like pictures!
It appears that it goes like this.....
Just need someone to confirm what I suspect!
Dan
84 Porsche 928 S Auto "US"
Old 01-14-2014, 12:46 PM
1979 5sp 928 project
I would say it needs to be plugged up for sure...especially if there is not a strange little hose that curves down and seems to want to plug into it. If I had mine at the house, I would go out and check it for you. I have an 84 as well. Plug it off and it will run and then do some research as to what actually goes there. When I get mine back to the house in about a week, I'll reply if not already answered. I would use a better plug though...that looks pretty rigged
1979 928 5sp project
1984 928S 5sp black on black
Old 01-14-2014, 03:30 PM
Network Native
Danglerb's Avatar
That is I think where the vacuum limiter goes in early cars and where the idle control goes in newer ones. Idea is that if you down shift with the throttle closed the vacuum may be sufficient to prevent combustion and cause a misfire.
Old 01-15-2014, 01:09 AM
MPDano's Avatar
Mike is correct, also called a "Decel Valve" and it's purpose if keep from backfiring upon deceleration. My S also did not have one but in order to comply with the Calif Smog Nazis, I got a good used one from 928 Intl and installed it.
That is a "huge" vacuum leak spot so if your going to ghetto plug it. Use new rubber/silicone pieces.
Vacuum Limiter (Decel Valve) Vac Route?
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 01-15-2014, 04:14 AM
Pete R's Avatar
I have it removed on my car. It has never backfired. It does however make driving a bit more harsh. It keep the rpms from slamming down after a lift, ans smooths out shifts. Also when I go from zero to full throttle at low rpms my car has a single studder, that it didn't have with that valve.
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold)
Neon SRT4 track car
Old 01-15-2014, 04:26 AM
It doesn't appear that I have a vacuum limiter. Maybe it was removed by the PO. I think I am going to plug it up tight, at least for now. once I have her up and running I will see if it makes sense then to install it.
Old 01-15-2014, 02:36 PM
MPDano's Avatar
I wouldn't bother unless required by your state smog. As Pete says, it doesn't do much anyways.
Old 01-15-2014, 03:03 PM
Kyle C
I believe the vacuum limiter/decel valve was equipped on the 5spd cars but not the automatics, right?
1978 928 5spd hillclimb special
1984 928S 5spd, 1986.5 928S auto
1983 944, 1984 944 track car
1995 Saab 900 S, 1997 Saab 900 Turbo, 1999 Saab 9-3 S
Old 01-16-2014, 06:10 PM
that would make sense, Mine is an Automatic
Old 01-16-2014, 08:26 PM
whatudrivin's Avatar
My automatic had some caps on those ports as well. Can't confirm that it was only manuals though.
\Brad/
'82 928 Automatic w/Competition Package Black/Red
Old 01-17-2014, 03:01 AM
My 82 auto has those caps. They have a part number I believe, since on automatics they are all capped (I'm pretty sure). I replaced both of mine when I was trying to hunt down a vacuum leak.
928sRUs can provide the factory caps. I don't have an 84, but the one you have looks really long to me. Also, I can't tell if the top one in your picture is capped at all.
Old 01-17-2014, 12:52 PM
MPDano's Avatar
My Euro has a Decel Valve and it's an Auto.
Old 01-17-2014, 02:51 PM
SharkHead
JhwShark's Avatar
My '79 Auto has them as well...I'm in California.
'79 928, 85k Opal Metallic
'99 BMW 540i, 97k Titanium
'72 BMW 3.0 csi, 85k km (euro Deutschland '82) Taiga
Old 01-17-2014, 03:08 PM
Pete R's Avatar
LOL, you can see the oil line on the bottom like after a flood
Neon SRT4 track car
Old 01-17-2014, 05:03 PM
MPDano's Avatar
Nah, that's age rings like on trees.
Old 01-17-2014, 05:38 PM
Thanks for the Pic Brad. Very helpful The top one on mine does have a cap on it that is in poor shape and has a screw clamp on it. The lower one was just kicking around on top of the engine. I am going to replace both caps.
I just received a box of parts from 928'sRUS that include some relays, and the fuel line Kit. kicking myself for not adding the caps to the list! Looking forward to putting things back together. ...Dan
Old 01-18-2014, 07:42 AM
the Fix
went to local auto parts store and picked up a assortment pack of "bypass Caps" there are about 6 rubber caps and two of them fit perfectly and only cost me $4.99. feeling good about my small step forward. Thanks again for the help!
Dan
Old 01-19-2014, 02:33 PM
MPDano's Avatar
That actually looks pretty damn good. Nice find. Maybe post the part number, place you bought. Pics of the Assorted pack and post in the Common Fixes Thread. I'll index it.
Old 01-19-2014, 05:00 PM
Pete R's Avatar
I did the same thing. They are a common plug most real auto stores have in a assortment box.
Neon SRT4 track car
Old 01-19-2014, 06:58 PM
Pete, I can assure you that it didn't keep those oil lines hahaha.
\Brad/
Old 01-21-2014, 05:58 AM
