-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/porsche-928-technical-forum/)
-   -   Safer than jackstands (revised) (http://forums.pelicanparts.com/porsche-928-technical-forum/790116-safer-than-jackstands-revised.html)
syoo8 02-14-2014 11:49 AM
For the air box. Time to change it, too.
Mrmerlin 02-14-2014 02:55 PM
The new intake parts look great,
I hope everything goes great.
NOTE before you try to start the engine,
take a 27MM deep socket,
and by hand, turn the engine over few times.
This might prevent a catastrophic failure.
NOTE more than a few owners have had a washer or nut drop into the cylinder,
and then simply by cranking the engine over they never felt the piston lock at TDC,
and thus destroyed the engine..
this simple precaution might have saved a few of these engine top end refreshes.
I would recommend this be done any time that the intake and injectors are serviced or removed
Crumpler 02-14-2014 04:54 PM
Also remember to remove 27mm socket from the crank after you test it.
My nine year old saved my ass last year.
As I was about to turn it over..."Daddy, is that supposed to be on there?"
Looks great by the way.
Dave.
syoo8 02-14-2014 07:21 PM
Are you using non-stock fuel rails?
syoo8 02-15-2014 06:31 AM
Odd- that's not what my fuel rails look like at all.
Dadddio 02-15-2014 03:29 PM
That's not an intake or fuel rails from a 86
AirtekHVAC 03-03-2014 06:51 PM
Wow.....great work!!!
antsmands 03-09-2014 01:20 PM
NICE Work!
Plexus928 03-09-2014 01:56 PM
Great, BRILLIANT!
AirtekHVAC 03-10-2014 06:49 PM
Woo! Sounds real good!
