1982 928S
georges 928S's Avatar
RE: rattle in sunroof
Hi Guys, my sunroof rattles when it is open, is there some kind of adjustment to be made for this problem. thanks in advance. Ed.
Old 01-21-2014, 06:59 PM
Network Native
Danglerb's Avatar
Nothing money can't fix on a Porsche, but could be something out of adjustment or a loose screw. If it bothers you I would try doing the normal periodic service to clean and lubricate and see if in the course of that you notice something obvious.
Old 01-22-2014, 12:06 AM
MPDano's Avatar
Yup, just sounds like something is loose. Here is a write up on when I disassembled mine, should give you an idea of how easy it is to take apart and put back together.
**MOST Common 928 Issues AND Fixes**
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 01-22-2014, 05:41 AM
Crumpler's Avatar
Easy yes, convenient not so much.
I remember when I thought I was lucky that I got one with a sunroof...
Old 01-22-2014, 08:41 AM
MPDano's Avatar
Here is a scenario that will make that easy fix even more inconvenient. If that piece that is most likely loose breaks off and jams into that long belt with teeth and breaks teeth, replacing that or even getting to that will make any grown man cry
Old 01-22-2014, 08:57 AM
