Yellowb1rd's Avatar
S4 not starting at all....
Pelicans....
I could use some insight here. After replacing my 89 motor with another S4 motor, the car will not start at all. I crank it over and over again, and it wont even attempt to fire. Also replaced the battery, the knock sensors, crank position, and a plethora or other stuff while the motor was out. I have updated CPUs in the EZK and LH, and have shark tuned with basic settings to get it started. Here is the profile:
Rotrex supercharger @ 6lbs.
36LB injectors
some facts:
the engine is getting fuel
the engine has spark (at both distributors).
NOID lights show that injectors are working (correct pulse)
Engine has compression
Original motor started and RAN with the same injectors, and SAME EZK and LH Eproms (no supercharger connected at that time).
I've verified that connectors on positive terminal are snug
There are two clicks when turning on the ignition (not continuous clicks, which indicates a bad LH)
Reground cams to original factory specs
Replaced ignition, and fuel pump relays.
Removed the fuel pump relay - Jumped the 30 and 87 contacts, and fuel pump ran constantly as expected, but car still did not start.
Other than replacing the motor, no other changes have been made. Any insight would be appreciated.
Old 06-03-2014, 08:25 PM
stepson's Avatar
#1-Is your harmonic balancer on backwards? Can you read the numbers on the harmonic balancer from the front of the engine? If it's on backwards, you can have fuel, compression, and spark, but the engine won't start because it'll all be happening at the wrong time for correct engine operation.
#2- Do the LH and EZF for the '89 have the same pin output as previous year computers? I know previous year computers can't be used in 89 and up because the older computers don't have the digital dash drivers. Maybe there are other changes that prevent correct engine operation.
John Curry (Drift King) 928OC member
Grand Prix White 1994 GTS AT (The GTS)
Black 1989 GT (The GT) and Cobalt Blue 1989 S4 AT (The Blue Car) 1986 Euro AT
Indishrot 1984 Euro S AT (The Stepson) and Black Metallic 1984 Euro S 5 speed (The Schwartz)
Old 06-03-2014, 10:29 PM
harborman's Avatar
"Other than replacing the motor, no other changes have been made."
Well this is a big "other". Did you do the motor work? Are cams back in correctly? So many variables to try and trace down. I would start with making sure the motor was put back together correctly and cams, timing gears have been checked for proper alignment with crank timing marks.
1986 928S
32 valve engine
All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires.
Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster
Old 06-04-2014, 05:35 AM
Network Native
Danglerb's Avatar
Fuel, spark, compression.
Do a compression test, same time I would attempt a start just prior to it (and pulling the fuel pump relay for the compression test) and check plugs for fuel.
Check the ignition timing.
Put the factory chips back in for now.
Any gas smell at exhaust?
Check fuel pressure.
Listen for injector click.
US 83 zinc metallic 5 spd, aka the nice car.
Euro 85 black, 5 spd, the fast rough track car maybe car. SOLD
Euro 84 red, AT, only car in garage in years, my parts car, soon to go last 7 years.
Old 06-04-2014, 01:19 PM
stepson's Avatar
In post #1, you state that the engine has fuel, spark at both distributors and compression.
Timing of at least one of those events has got to be incorrect, or the engine would run
Old 06-04-2014, 08:20 PM
Yellowb1rd's Avatar
I am beginning to agree with this, although the harmonic balancer is certainly on correctly.
The car is an '89 btw with 89 EZK, and LH.
Old 06-04-2014, 10:49 PM
Yellowb1rd's Avatar
Do a compression test, same time I would attempt a start just prior to it (and pulling the fuel pump relay for the compression test) and check plugs for fuel. --> I did a leakdown on the motor, and the numbers are decent (done on the motor when it was still on the shipping crate).
Check the ignition timing. --> Timing is 3 degrees BTDC for better mid-upper range
Put the factory chips back in for now. ---> EXACTLY what my next plan is, but one of the pins on the EZK CPU broke off removing it, so I need to scrape up another set.
Any gas smell at exhaust? --> there is fuel smell after cranking for about a minute. It could be flooding...
Check fuel pressure. ---> has pressure (nice high pressure spray when unscrewing the pressure relief cap), but have not yet checked the pressure with a gauge.
---> injector clicks TWICE when turning on the ignition.
Old 06-04-2014, 10:56 PM
A Wrench
SeanR's Avatar
Failed LH.
'88 Supercharged and lots of other fun stuff.
Old 06-05-2014, 06:50 PM
Yellowb1rd's Avatar
Originally Posted by SeanR View Post
Failed LH.
My understanding is that CONTINUOUS clicking indicates a failed LH ECU.
Old 06-05-2014, 08:32 PM
Petie3rd
Mrmerlin's Avatar
^^^^ lets put it another way,
any clicking of the injectors before the engine has begun to crank over,
indicates computer failure
Old 06-05-2014, 08:50 PM
Yellowb1rd's Avatar
I certainly appreciate the feedback, but interestingly enough, when I jump the fuel pump relay where it is constantly running, it still doesn't start. The LH is essentially bypassed at that point. That makes me doubt a faulty LH.
Old 06-05-2014, 09:09 PM
Network Native
Danglerb's Avatar
Fuel pump running doesn't make the injectors open, only the brains do that.
When Sean says its X, generally its X.
When Stan says its X, generally its X.
When Sean and Stan both say its X, its X.
Old 06-06-2014, 12:03 PM
Petie3rd
Mrmerlin's Avatar
Thomas ....the solution, take your computers and put them in a good running car/engine, see if the other car will run
Old 06-06-2014, 05:40 PM
Yellowb1rd's Avatar
BTW, the clicking turned out to be the fuel pump relay. Completely normal. It's just a lot louder with the panel off.
Old 06-06-2014, 07:11 PM
Yellowb1rd's Avatar
Correct, BUT the Noid light shows the injectors are pulsing correctly. I would assume that if the LH was bullocks, there would be no pulsing. Correct me if I'm wrong.
ALSO, the clicking turned out to be the relays, which is completely normal. Go out and turn your ignition on and you'll hear those clicks too. It's just a lot louder sound when the fuse panel and carpet are out of the way. I realized this because I tested the relays using my own power source, and BEHOLD, same sound! I'm also presuming that the continuous clicking that indicates a bad LH would be caused by sending incorrect signal via the relay, hence opening and closing continuously. Remember, when starting an autobox 928, the fuel pump initially does not run continuously.
Let's not have pissing matches here by saying things like me right + him right = We're right. Let's try to figure out the issue together, because that's what these forums are for. I'll find the issue myself eventually, but I'm trying to facilitate the process, which I'll share on the forum for all to benefit from. The bad LH road we're going down here is not the right one. If I'm wrong, I'll be the first to broadcast it, but if faulty LH, 'no flashy' on the Noid light. Since the injectors blink (as shown by the Noid light- blinking indicates a proper signal), the LH is probably just fine, else what is the purpose of the Noid light diagnostics?
The incorrect ignition timing seems more likely than a bad LH. It's definitely firing. It's definitely getting fuel to the cylinders. But is it firing at the CORRECT time?
Old 06-06-2014, 07:13 PM
Petie3rd
Mrmerlin's Avatar
Thanks for the update.
BTW I am providing you my best guess, given the information you are providing.
Relays clicking when the key is turned,
is completely different than the fuel injectors clicking when the key is turned.
I would still like you to install your computers into a good running car ,
they dont have to be bolted down.
the timing is set by the computer so its not something that you can adjust,
the firing order can be changed by mis routing the plug wires,
and or the timing marks could also be off, usually its a damper thats installed the wrong way
Old 06-06-2014, 09:38 PM
tisilrad's Avatar
timing belt
I think the thing to do here is to check the tension of the timing belt, if tension is loose it is possible the belt has jumped a cog or two and the engine is now out of cam timing. I know it is a lot of work but at this point if everything else is coorect(i.e. ignition, spark and compression) Only timing is left for propre engine function.
Heraclitus: 1987 porsche 928S4 5 speed black/black moneypit
Old 06-07-2014, 12:03 PM
tisilrad's Avatar
timing
If the engine was recently assembled and has run since then, it is possible retensioning will be necessary(as the dealer would require a scheduled retensioning after something like 1500 miles) If this is the case my thoughts on the timing belt jumping cogs would be likely. The timing belt light should come on possibly if tension is loose..but it is also easy to incorrectly reassemble the tensioner warning system wiring... You stated that the engine has compression so i am assuming there are no bent valves..
Old 06-07-2014, 12:10 PM
Fixer's Avatar
Have you done this?
Have you simply pulled plugs to see if its getting fuel.
If you've got fuel, spark and compression then Harborman's advice
would be the first step (i know you already know this)
Get the basics covered first.
You'll get it running Yellowbird
Matt Mariani @the_r_institute
Authorized Retailer
FIKSE Wheels
Mod Italian Wheels
Maxilite classic wheels
Old 06-07-2014, 12:22 PM
stepson's Avatar
Good Point Stan!
Yellowbird,
The cylinders are numbered front to back 1-4 on right side of car
front to back 5-8 on the left side of the car.
Where the plug wires put on in that order?
Old 06-08-2014, 02:13 PM
