I searched for and didn't find so thought we could use one of these threads..
I drained my power steering fluid and refilled with Dexron ATF, cleaned the res and cap real well and replaced the seal. The cap dip had fallen off and was at the bottom of the res. Very clean and no longer losing fluid through cap, Looks nice. Then took off steering wheel & greased horn contact and went to work. Took about 15 minutes. Always do something before work lately I have been driving it a lot. running great
Matt Mariani @the_r_institute Authorized Retailer FIKSE Wheels Mod Italian Wheels Maxilite classic wheels |
Installed a rebuilt steering rack and new steel balljoints on the 80. Fixed the upper door/window trim on the 94. T
European Shark
Replaced the pull-wire for the hood release, as well as the backing to the handle in the cabin.
Replaced (well, put in place, since the ones that were there had fallen of by themselves) the aluminum shields that direct airflow from the ducts in the bumper to the front brakes ![]() Today: CV-axle boots Those center-nuts are crazy-tight!!!![]() Last week I did some other stuff, pics should be self explanatory: ![]() ![]()
1978 Porsche 928 Euro 5spd. Silver metallic/Black 1986 Porsche 928 S2 Euro 5spd. Meteormetallic/Grey. *Crashed* Owning a 928 is risky business - but sometimes you just gotta say "what the fudge". |
Awesome T and Riber! I will try an take photos FNO, hope the rest also take pics to 'show your work'
Kool
Epoxied the crack in my fuel strainer hub Sunday, let sit and then dremled it smooth yesterday, replaced the strainer, filled tank.... No leak yet...we will see....
Ron 1978 5sp (#30) project-Wreckscue, 1979 5sp Euro Project 1982 5sp resto project, 1985 Auto S3 1984 Parts car (the fire car) 1987 s4 (parts, or maybe project) (Yes, I now have 4 project Sharks) |
Got my tank back from being cleaned late last week. Been too busy to get the correct size fuel hoses to put it back on. Just need vacuum hoses to get everything put back together. I think I can try to start afterwards. =)
\Brad/ '82 928 Automatic w/Competition Package Black/Red |
It seems like I can never get enough light under my hood when I'm working, so I scratched together some canned lights and lumber that was left over from the basement. Now it's like an operating table!
I have not decided if it's pure genius or I'm WT. ![]() ![]()
Dave 1986.5 Manual Blk/Blk |
Nice operating table Crumpler and nice 928, motor looks spotless. How did you get that nickname, accidents?
Ron and Brad hope your gas issues are solved! ![]() This will be a great thread, motivates..going to clean motor before work tomorrow to prep for my electric fan upgrade. Matt
Thanks Fixer. Your 83 is quite sharp.
I will try and get you more info on fan specs. tonight on the other thread. No accidents in history but I tend to create collateral damage when working on car.
Thanks Dave? Crumpler. I got the e fan in mail and it is installed. removed the AC con fan (wasn't working) and set it up to push air through (1500 cfm, 20 amp current draw) once through the AC coil cfm should be 1300, thermostat works well (probe type) happy to have no air pump and now sans the fan belt. saved 8 pounds O.aA.. Nice product for the price, will test all weekend and update you all.
Have a great night! ![]() ![]() NOTE: This fan set up was changed to PULL and worked much better. It has been fine in the 90 degree heat.
Matt Mariani @the_r_institute Authorized Retailer FIKSE Wheels Mod Italian Wheels Maxilite classic wheels Last edited by The Fixer; 06-10-2013 at 03:55 AM.. |
Kool
I got her running, again...no fuel leak yet. Prepping for brake lines, clutch line, and blue hose next. The brake line fittings are wicked rusty. I have been soaking them in Kroil every day....
Good work you guys!! Had my first battery drain issue in 3 years. Jumped it drove about 100 miles. Checked battery and charging. Seems okay. I win today.
Spent the past 3 days detailing the shark. Clay bar, scratch remover, 3 layers of Zaino polish and 2 layers of Zaino wax. Also put on leather conditioner and rubber rejuvenator. The car is very shiny now. Tomorrow I'll take it out for some good pictures.
1982 Porsche 928 - Blue |
Performed the tail light harness mod. Worked great but taillamp dummy light stays on. Why is that.
88 928 S4 Black, Black and Grey Interior Alpine head unit & amp, Bazooka Tube, Viper 5704 Smart Start GPS tracking, Devek Headers, Flowmaster 40 3" with Resonator, Auto Authority chips. Custom Luggage Cover. Traded - 86 944 Turbo Guards Red. RIP - 85.5 944 Guards Red |
Petie3rd
^^^ probably a bad side marker bulb,
or the connector for it is dirty, check along the rear edge of the floor of the hatch for the side marker light connectors, they are 2 pin
^^^ Stan ^^^ 2019 BMW K1250 GS 2016 HD RK 1988 S4 Auto , Elfenbein Perlglanz, Pearl Gray 1982 5sp Met black and tan sport seats |
Now that u mention that...my drivers rear sidemarker doesnt work...replaced with new bulb and also checked fuses same result...ill peel carpet up and check that connector
Changed engine oil and filter, changed autotrans filter need to pick up fluid, Check diff fluid for level.
Rich Newnan, GA 1981 928 Coupe Black/Tan Sunroof delete |
Cleaned front of motor, prep for TB replacement, (i can't get my pretty hands dirty) replaced my plugs, looked closely at plug wires, they look good and operate fine but are very old (Beru).
Tomorrow Camshaft drive belt, excited
Found a new rear wiper blade in garage. Installed it. Woohoo. Checked out engine bay. Made a list.
Too much, too little driving
