honerboys's Avatar
some quick questions
I took these seats out so long ago I can't remember how they were - there are two kinds of plastic caps that cover the rails - I have two sets of these I think from 2 separate cars - the long fits on the outside easily - however I can't get the long ones to fit on the inside rail (too much carpet interference) - so i'm thinking the short ones go on the inside - but I can only find two of them and the screw holes won't line up for the front inside rail - also the front inside rails have rubber caps over their screw holes - so how's it go - also what's the capped connector that comes out of the ecu connector - thanks
long and short plastic pieces
capped connector
covered front inside screw holes
84 928 S - SOLD
2012 Cayenne S
Old 08-14-2014, 03:20 PM
Dean_Fuller's Avatar
PET manual page 335 shows how the trim pieces fit at seat.
The called plug looks like the oxygen sensor that SHOULD be in the exhaust via a hole in the tunnel.
1980 AUTO Synergy Green Metallic / Black & Grey ( my son's)
1989 Auto Slate Grey Metallic / Cashmere & Black (mine)
1982 5-speed White / Black sport seats ( brothers )
Old 08-15-2014, 06:49 AM
Can't figure out how to attach just one page out of the PET so here is a bad pic.
Looks like the rail with the rubber caps is the INSIDE rail. Outside rail should have tabs for trim attachment....or you have just inside rails only.
Old 08-15-2014, 06:55 AM
PET on the oxygen sensor. This still should be in the exhaust with or without the catalytic converter in place.
Old 08-15-2014, 07:06 AM
honerboys's Avatar
thanks dean - so I guess the front inner rail has no cover? - my oxygen sensor is installed but it plugs into 3 different wires - i'll pull the CE panel and do some investigating
84 928 S - SOLD
2012 Cayenne S
Old 08-15-2014, 08:19 AM
Yes...looks like the inside rail does not get a cover in your cars model except on the back where the small cover attaches.
Old 08-15-2014, 12:11 PM
honerboys's Avatar
I pulled the CE panel to get a look behind it - the 3 wire oxy sensor on this car connects to three wires that look to be factory - two go to a 2 prong plug (heating wires ?) - the other looks like a standard oxy 1 pin plug - ? - do some of these cars have more than one oxy sensor - am I missing one - while I have yet to drive this car (and I've owned it 3 years) it starts right up and idles ..ok - revs ..ok - ????
84 928 S - SOLD
2012 Cayenne S
Old 08-16-2014, 06:41 PM
Can you post a pic of the SOURCE of both plugs?
Old 08-16-2014, 07:45 PM
honerboys's Avatar
here's pictures of both the mystery capped plug and the oxy sensor coming out of the tunnel
mystery plug
oxy sensor
84 928 S - SOLD
2012 Cayenne S
Old 08-17-2014, 09:07 AM
My manuals are at the shop and it may be a few days before I make it over there. Check the wiring diagram and see if you can tell what they are. I will look when I get a chance.
Maybe a diagnostic plug?
Old 08-18-2014, 07:10 AM
