Motor Block number 1985 Euro 16 Valve
Whats the Block number for the 1985 Euro 16 Valve motor to check for the right motor in the car if anyone knows Has twin distributors on the drivers side next to each other
Thanks in Advance ![]() What is the H.P. of that Year Motor ? is it 300 HP ? |
84-86 S - 4-auto (Euro) 4.7L-16v M28/22 310 295 10.4:1 LH-Jetronic 150 6.7 15.5 3308
84-86 S - 5-man (Euro) 4.7L-16v M28/21 310 295 10.4:1 LH-Jetronic 155 6.2 15.2 3308 M28/22 for auto M28/21 for manual 310hp, 295 ft.lbs |
Great ! Now I can Identify for sure the Engine 84 through 86S M28/22 Auto Trans So this is a non Interference Motor then with the exception of Carbon Build up It's possible to get some Damage like when a T. Belt Brakes I Have Heard of these Engines as being Very Desirable . I also remember reading about the Dual Distributor but from 1 Distributor Body with the 2 Caps . |
I would consider that motor an interference motor. My '84 Euro S blew the TB and I got lucky. On Rennlist, we came to the conclusion that earlier '84 Euro S models had some crossover parts and may be non interference. An '85 would more than likely be interference.
Picture of a twin dizzy motor ![]() |
I am also smarter than to attempt to duplicate this feat. No need to tempt fate IMO. ![]()
John Curry (Drift King) 928OC member Grand Prix White 1994 GTS AT (The GTS) Black 1989 GT (The GT) and Cobalt Blue 1989 S4 AT (The Blue Car) 1986 Euro AT Indishrot 1984 Euro S AT (The Stepson) and Black Metallic 1984 Euro S 5 speed (The Schwartz) |
Interference Motor VS Non Interference Motor
Great Photo Doug : Thanks Much
Referencing a Interference Motor VS Non Interference Motor Related to a 1985 Year Model with this Motor What's your opinion or Knowledge of the Interference Issues related to damage . This Car has a Broken Cam Gear Owner says but the Cam looks to be OK MY Take on it is as Follows : However this is just a Guess not Fact Knowledge (1) Perhaps ? Due to the Higher Lift on a 1985 Euro Camshaft the Motor becomes a Interference Motor (2) Perhaps the Euro Pistons having higher Compression come up higher into the Combustion Chamber , Or the Combustion Chamber is smaller creating Higher Compression , Thus becomes a Interference Motor ? If indeed the Motor Is Damaged Internally I expect their is no way to know the Damage until Tear Down Like Broken Block . Broken Head . Broken / Bent Valves . For Example if a Valve Brakes off and gets caught in the Cylinder as the Piston comes up Major Damage could Happen including the Block Perhaps . |
928: Serial Enabler
Leak down test. After cam repair. Could be cam snout break. Not gear break.
Leakdown test done by somebody who knows what they are doing can determine if valves are bent. Oil change right now, along with send away analysis, plus assessment of cut open filter could determine if engine is toast. Theoretical. Best course, buy it cheap, not confirming extent of issue, then plan for worst, hope for best How is interior?
84,85,86 928 cars |
928: Serial Enabler
You'd better have pretty deep pockets and/or some strong access to mechanical support, else you are looking at a heap of frustration.
84,85,86 928 cars |
80 928
-Kerry |
( I have a House in Rancho area more or less off Decatur but am in my N. CA house now ) Any Old way yes it would be nice if the Motor was not ruined lol , I have decided to assume that it is damaged perhaps beyond repair and see if we can come to terms or not. About your Euro Cam's they are not on Euro Heads are they ? perhaps they are not sure I remember something about them in a old post you had . Personally I would have considered 78 or 79 Cam's for your car with more low end but still high lift almost the same as the Euro Cam's . I am hoping to get this car and discover the motor is still able to be fixed ? humm Not my first time around to fix a 928 Motor but rather my second lol. for the Skeptic's I have rebuilt many many engines of all sorts Professionally without Issues . A Porsche Engine is different however I remember the 911 Motor I Built and dialing in the cam's was interesting I remember . Thanks for reply Last edited by aluminum; 09-10-2014 at 02:51 PM.. |
deep pockets
He also Says the Cam is ok lol He Claims to be a Mechanic but you know how that go's when it comes to a 928 Mechanic and a " Just Mechanic " yes their is a difference . Personally I think I am still learning the 928 but with some hands on . I am going to call him this evening about the Car and try to talk money as if the car is Damaged perhaps much deeper then he is Knowledgeable of and try to enplane why. Says interior is good and the Dash is good not cracked ? I find this great news but hard to believe Related to your statement lol " You'd better have pretty deep pockets and/or some strong access to mechanical support, else you are looking at a heap of frustration. " For access to mechanical support I shall look in the mirror and the deep Pockets I have be Known to reach Deep when buying International Airline Tickets and Property's . Car's I skimp on but have and drive them . My Only Regret and perhaps unfortunately are the Photo albums of all the Car's I sold that I wish I still had . Thanks much for your reply you have a lot of good points and great helpful information to share very generous to say the least . I like to know a 928 has a deserving owner ! |
928: Serial Enabler
If only gear, the mechanic would have it running. Calling bs on "mechanic", as its a 30 min job to swap the cam gears. 45 min with beverage-in-hand.
84,85,86 928 cars Last edited by Landseer; 09-10-2014 at 05:09 PM.. |
[QUOTE=Landseer;8256051]If only gear, the mechanic would have it running. Calling bs.[/QUOTE
I Doubt he knows how to Open up the front of it let alone how to line everything up and set the Belt . thinking Positive rather then Negative The truth is in the Pudding . Perhaps I well never see the car ? humm |
928: Serial Enabler
Its easy, both covers off, loosen the belt, install the gear, tighten the belt, start it.
Couple of 17mm wrenches, 10 mm socket. Fact is, you don't even need a tension measuring device, honestly, though its recommended. ( I set them by feel all the time ). Its that easy. Sounds like you are collecting your information, good beginning. But to know its not the camshaft, instead is the gear... he already has the covers off. You now know too much to get scammed, hopefully you can pick it up cheap and make it work.
84,85,86 928 cars |
80 928
-K |
I'm with Landseer on this. Also, It's a combination of cam, larger valves and high comp piston that make it interference. I think it's mostly due to the pistons, there is almost no valve relief at all. When I was rebuilding my Euro I saw documentation somewhere that different pistons with different comp ratios were used in these "euros".
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold) Neon SRT4 track car |
Talked to the seller yesterday and my impression is that he pulled at least 1 timing cover and he says the gear is Aluminum and Broken right in half ! So Far we are unable to come to terms . I explained to him about the interference engine Issues but seemed to fall on deaf Ears perhaps . Also mentioned the different Engines that come in that year Car and such . Say's he got car from his landlord bla bla bla > My take on it is that perhaps he got the Car that way but he says he drove the car over to his " shop " and it ran fine , Transmission worked fine and such . Then upon starting the Car again is when it broke . I Did ask if he took off the Valve Cover and inspected the Camshaft and he said NO ! This tells a story , However according to him the cosmetics are good , Dash is perfect , Seats are good , Windshield is good > so I am trying for the Car but at a realistic price ****** I also was thinking I could just do the Timing belt by Feel ! but I do have the Kemp Tool and have used it so far . I will wait a few days and call him again > My Take on the Car is that as it is It's a parts Car that may need a Engine . I believe I have read the more common Engine US Type will not just go right in as it need a different wiring harness / Computers / MAF and perhaps more . So as a parts Car worth far less then with a Running Motor . Thanks for the Reply Last edited by aluminum; 09-11-2014 at 10:36 AM.. |
Ask if you can pull the covers yourself. You need a 10mm socket and less time that it took to type that paragraph, It will end a lot of confusion.
Network Native
Given so much is unknown, what is a realistic price?
Cam gears are aluminum, but they don't break without a reason. Perfect dash has a lot of appeal, but if you can't keep it garaged, it might stay perfect a short time. Without a cheap price it needs expert eyes on it before guessing on reasonable price. |
or course the car must be as described and I have not seen the car yet ( is a Long drive ) So far I have made a offer and it stands to date , |
Thread Tools | |
Rate This Thread | |
