Help! main beam doesnt go off
Hi guys,
I just got home and when I turned off the lights, the main headlights had retracted BUT the lights (main beam) stayed on! I tried pulling out every relay but only after I took the 2 fuses off the lights turned off.
Does anybody familiar with this phenomenon?
The weird thing is that when I turn off the lights, while the main head lights retract, the lights are off. When they are fully retracted, the lights comes on again
Any ideas?
Porsche 928S 4.7L 1980 European redhead
Old 11-14-2014, 08:21 AM
Perhaps the problem is with one of the relays...do have any idea which relay is responsible for shutting down the main beam after the headlights retracts?
Old 11-14-2014, 10:52 AM
Network Native
Danglerb's Avatar
I've seen this before, somebody will pop up with an answer.
Old 11-15-2014, 10:07 AM
I hope so...this is very frustrating
Also, from time to time, when I turn the light switch on the headlights go into a loop in which the headlight engine wont stop. Is this the big relay that went wrong or something also in the headlight engine itself (there are couple of diodes according to the electric schema)?
I noticed that when I touch the relay after not driving the car for a while it was hot while the other relays were much cooler.
Any ideas will be highly appreciated!
Old 11-15-2014, 11:59 PM
harborman's Avatar
Not sure but there could be limit switches on your head light motor.
1986 928S
32 valve engine
All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires.
Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster
Old 11-16-2014, 01:47 PM
Network Native
Danglerb's Avatar
Porsche 928 Forums dot com - View topic - Headlights work, but will not go up...
928 Tech Tips
Old 11-16-2014, 03:10 PM
Thanks for your help and advice! The link looks good but this is not the problem I have Anyway, do you know if there are some instructions on how to remove the headlight motor? I found something in Rennlist but it wasnt too clear..
Old 11-17-2014, 04:13 AM
Hi guys,
After troubleshooting this problem and understanding that the problem is within the headlight massive relay, I decided to try and simply replace the small electronic components instead of buying a new relay. I bought all the components (except the resistors) and started to replace them. I started with the 2 transistors (marked in red) since they were most likely went wrong and...SUCCESS!!!! After replacing both of them, the relay came back to life!!!
The component cost me ~2$ so it is a big save and a very easy job.
Old 01-19-2015, 05:28 AM
harborman's Avatar
Maybe you can post the transistor types and where you got them.
1986 928S
32 valve engine
Old 01-19-2015, 05:41 AM
The transistor type is written on the transistor body (I dont have it with me). All the components are very common and can be easily found in any store that sells such components. I am not from the US so I cant recommend on a shop
Old 01-19-2015, 05:50 AM
