A. Miguel (guest)
Guest
Posts: n/a
1979 928 Catalytic Converter and Oxygen Sensor Question
I sent my '79 928 to SouthAmerica for "future enjoyment". Before the car was shipped, the local dealer here in Canada suggested that "at least" one of the cat converters will need to be changed soon. Since in m country there are no emission regulations for a car this old, I was thinking in removing ALL the converters and replacing them with a sport custom madeexhaust, would this change help the car's performance?...what about the oxigen sensor?
Your opinion will be appreciated.
Many thanks.
This post was auto-generated based upon a question asked on our tech article page here:
Old 02-26-2015, 08:21 PM
A professionally engineered exhaust without catalytic converters will increase performance. You may find a decrease in throttle response at lower RPM, but you'll pick up some power at higher RPM. As for the oxygen sensor, I would keep the sensor in the loop. Reason being when you are cruising the sensor will be mindful of the air fuel ratio saving fuel, when you mash the throttle to wide open, the DME (engine control module) ignores the oxygen sensor and the fuel mixture goes to a rich mixture which Porsche engineers have determined works better for producing power. So removing the sensor will not increase performance. Remember that you'll be driving a car with no catalytic converters, should you choose to remove them, and the exhaust fumes will be dramatically increased.
- Casey
Fleabit peanut monkey
Bob Kontak's Avatar
Good input, Casey.
1981 911SC Targa
Old 02-26-2015, 08:23 PM
rjm65's Avatar
CIS Kjet on the '79 doesn't have an O2 sensor.
Raymond
1979 928 5 spd
Old 02-27-2015, 12:21 PM
MPDano's Avatar
Specs on all that MY
77-79 - 3-auto (US) 4.5L-16v M28/04 219 245 8.5:1 K-Jetronic 140 8.5 16 3373
77-79 - 5-man (US) 4.5L-16v M28/03 219 245 8.5:1 K-Jetronic 143 7.5 15.5 3285
77-79 - 3-auto (Euro) 4.5L-16v M28/02 229 250 8.5:1 K-Jetronic 140 8 16 3197
77-79 - 5-man (Euro) 4.5L-16v M28/01 229 250 8.5:1 K-Jetronic 143 6.8 15.5 3197
Porsche 928 Forums dot com - View topic - 928 Engine Types & Performance Data
Sounds like your local dealer is taking you for a "ride."
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 02-28-2015, 12:03 AM
