Hi folks'
The alternator on my '82 auto seems to be going bad. It's a valeo brand. These are priced higher than some of the other brands i've seen. I don't have a lot of money, so I was wondering if any of the other ones would fit the car. It would have to fit right in like the original. |
Usually it's the built on voltage regulator that goes bad. Should be a part number on it and then contact Roger at 928srus
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior 1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
928: Serial Enabler
You can replace with Delco 105 amp from, for example, 88 Camaro. i'm replacing one this aft on 1984 USA, which also will work on 82. You need a Dorman pigtail and you need to loose the cover, a slightly shorter belt. Search here and rennlist for other tips.
84,85,86 928 cars |
Well, I already tried the voltage regulator and the camaro switch is more work than I wanna do . thanks for the help guys. At least it's not 928 weather.
