davetr's Avatar
turn signal problem
no left turn signals, after a new relay th right works fine, still no left, th indicator on th dash lights up n blinks fast, realay also clicks fast, no power to th fuses, all th bulbs are clean and new, im thinking signal sw ????
Old 03-16-2015, 04:19 AM
Jose_JGC's Avatar
Before going after the signal switch or the turn signal and flasher relay, I would check that both front and rear bulb's + poles are in contact with the signal's + tip. It could also be a bad ground, as the ground in these signals comes from a wire attached to the frame and these can corrode. Other thing could be the bulbs, are these really new or just look new?
Jose
Old 03-16-2015, 05:11 AM
Jose_JGC's Avatar
Oops, I thought I was in the 911 Tech.Forum...
Anyway, easier things should be checked first, I believe also applies to the 928.
Jose
Old 03-16-2015, 06:38 AM
davetr's Avatar
yep I checked th easy stuff first, when I turn on th right turn signals I get power to th right fuses, everything works fine, no power to th fuses on th left side at all
Old 03-16-2015, 07:18 AM
Network Native
Danglerb's Avatar
Playing with electrics on the 928 its essential to have a set of wiring diagrams for your specific model, which are included in the set of CD's from Roger. Home - 928s R Us Porsche Parts Store
Old 03-17-2015, 02:45 AM
davetr's Avatar
I was messing w th 4 way flasher switch last night, now all th turn signals work ???
Old 03-17-2015, 09:44 AM
Jose_JGC's Avatar
Glad to know you fixed it. So we may conclude that it was a bad contact in the flasher switch.
Old 03-17-2015, 01:22 PM
davetr's Avatar
and this morning no left blinker again ughhhhhh lol
Old 04-07-2015, 04:19 AM
My right signal did not work and it turnout out to be bad contacts in the fuses going to the lamps. Good idea to clean electrical contacts as you have things open. Caig Deoxit work well.
Old 04-10-2015, 05:12 AM
928-Electrics Guy
Alan in AZ's Avatar
I'd suspect the fuses (and fuse holders) first too - check both fuse HOLDER terminals with the fuse in... and don't just look at the fuse - to test use a DMM.
Alan
1994 928 GTS Black/Black Manual
Old 04-18-2015, 07:32 AM
davetr's Avatar
fuses are all clean and good, I messed w th 4 way sw and th blinker worked, till yesterday, lol
Old 04-20-2015, 11:04 AM
