Starting issue after engine is warm
SharkHead
You don't give much details.
A general known issue is a failing/failed Fuel Accumulator will cause a warm no-start condition.
'79 928, 85k Opal Metallic '99 BMW 540i, 97k Titanium '72 BMW 3.0 csi, 85k km (euro Deutschland '82) Taiga |
Network Native
Every model year had both US and Euro models, and lots change by model year.
Early CIS car nothing like L or LH. |
Check the fuel pressure regulator. Pull the vacuum hose off and check for a gasoline smell, if yes then the diaphragm is shot.
Ray 1988 928 S4 5 speed "Loud Cars Save Lives" 1984 Carrera 3.2 coupe "The Mistress" |
S4hounddog: thanks for the tip, I'll check it out. I was at work when I posted initial post and was in a hurry. The 928 in question is a 1980 Euro M28/11 engine with manual transmission. Engine always starts without any issues, but after driving a bit it does not want to start. I stopped for fuel and could not get it started without removing air cleaner filter and lightly pushing down on sensor plate. Appreciate any additional input on this matter.
SharkHead
While, or before, you are sniffing for gas...
check in right rear wheel forward compartment where Accumulator is for gas as well. On the '80 I do not believe you have a return line from Accumulator, and you would observe gas smell from a failed Accumulator.
On my '82, the problem was an inexpensive check valve on the fuel pump. Easy starts when cold but a pain in the ass even during the short amount of time to fill the tank at a gas station.
George in Indiana 928 Weissach #153 Cayenne S |
Network Native
80 Euro is CIS like the US 78/79. After the major failure smelling is done, you need a set of CIS fuel gauges and a shop manual to check pressures.
Thread Tools | |
Rate This Thread | |
