Porsche 928s Tacho Signal
Hey everyone, new here.
Recently I purchased a 1985 928s automatic. I have no signal going into the tachometer and wanted to check where the tachometer signal is originating from. I have replaced the tachometer and cleaned the connections on the back of the pod. If someone could tell me where the signal originates from I'd appreciate it.
Old 03-15-2015, 04:35 PM
Recovering dismantler
neil30076's Avatar
Do you have a wiring diagram, and do you know where the EZF is located? If so, that's where it comes from. Starting at the inst panel its via connector B-2, out on a green wire to J-11 on CE panel, loops out to W-11 on same panel to EZF-16.
Neil
2009 Mini Cooper
2004 Mercedes CLK500
2024 Subaru Outback Touring XT
2020 Entegra Coach
Old 03-16-2015, 04:49 AM
garylewa's Avatar
the signal is from a reed switch attached to the outer housing of the transmission. IIRC, it is a round sensor held down by one screw.....you should be able to see it.
'83 928S - Basalt Black Metallic w/Cocoa Brown leather
Old 03-29-2015, 06:21 AM
Petie3rd
Mrmerlin's Avatar
Gary are you talking about the round thing bolted to the rear of the transmission?
Old 03-29-2015, 07:56 AM
928: Serial Enabler
That's speedo pickup
84,85,86 928 cars
Old 03-29-2015, 10:51 AM
Sorry for the extremely late reply, been swamped with school work. Thanks for the replies everyone. I do have a wiring diagram and I see now the trace back from the tachometer to the EZF. My new question is when measuring connection B-2, should i be looking at the voltage or something else? I measured in voltage today and was getting at idle ~12volts, when i depressed the gas peddle the voltage would drop slowly. No life in tachometer still.
Old 09-07-2015, 06:35 PM
Tags
928 , tacho , tachometer
