Ramp's Avatar
Stalling '86.5 - Quick help
Just bought first 86.5 928S, one owner, 41k. Just delivered yesterday. Ran fine, took it this morning to get gas (on reserve) before I started to start the sorting process. Ran fine until after I filled her up. She starts fine, idles smooth but when you give it gas she stalls.
I had hoped to keep her running while I started to sort out the electrical gremlins but oh well.
What should I be checking first ?
Thanks and here we go.
'86.5 Porsche 928S
'87 Porsche 3.2 Cab
'12 Jaguar XJ
'14 Mercedes GL550
'16 Mercedes C300
Old 12-02-2017, 08:43 AM
harborman's Avatar
I wonder how long this car has sat? Any maintenance history? Have all the filters been changed? Sounds like it is starving for air or gas or both.
1986 928S
32 valve engine
All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires.
Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster
Old 12-02-2017, 09:48 AM
honerboys's Avatar
^^^^+1 - could be gas in tank has been in there a while - some sediment in bottom of tank - you stirred it all up when you added gas and now it's clogging something - screen, filter, pump, injectors? - might pull end cap off fuel rail and check flow and pressure - carefully
84 928 S - SOLD
2012 Cayenne S
Old 12-02-2017, 09:54 AM
Ramp's Avatar
The car has been driven but not driven much in the last 6 months or so. It needs to be fully sorted which I planned on but mechanically the car seemed like a DD.
I'm inclined to think it's stirred up crap from the tank - eve n the way home from the station she ran fine. Onl started when I went to take her out again.
Before I check fuel rail should I replace filter ?
'86.5 Porsche 928S
'87 Porsche 3.2 Cab
'12 Jaguar XJ
'14 Mercedes GL550
'16 Mercedes C300
Old 12-02-2017, 11:24 AM
stepson's Avatar
Check Temp II and MAF
John Curry (Drift King) 928OC member
Grand Prix White 1994 GTS AT (The GTS)
Black 1989 GT (The GT) and Cobalt Blue 1989 S4 AT (The Blue Car) 1986 Euro AT
Indishrot 1984 Euro S AT (The Stepson) and Black Metallic 1984 Euro S 5 speed (The Schwartz)
Old 12-02-2017, 01:30 PM
Ramp's Avatar
after sitting, she started right up and drove fine again.
Should I be thinking tank cleaning or just change the filter ?
'86.5 Porsche 928S
'87 Porsche 3.2 Cab
'12 Jaguar XJ
'14 Mercedes GL550
'16 Mercedes C300
Old 12-02-2017, 03:06 PM
harborman's Avatar
If it is now running OK, I would drive it and run some gas through for some miles. Then put some Techron in the tank and drive again. You may want to put a new gas filter on. There is also a check valve on it that might need to be cleaned. Do the simple things first!
1986 928S
32 valve engine
Old 12-03-2017, 05:32 AM
