Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
How to mount heat shield below turbo
I've got this heat shield and I believe it fits over orifice in the engine carrier. The orifice(just below turbo)(does something fit in this orifice?) is shown in the old catalog on page 76 and page 131 in the 85-88 catalog. I cannot get the screw holes to line up no matter how you try fitting it on. Does it fit there? What could I be doing wrong?
Any help greatly appreciated. I'm almost done with the job, but can't get my brain around this heat shield.
Thanks,
Ed
Old 07-11-2018, 01:51 PM
Administrator
Dmitry at Pelican Parts's Avatar
Hello - take a look at the link below to a tech article from our site - perhaps it'll help you troubleshoot.
https://www.pelicanparts.com/techarticles/Porsche_944_Turbo/70-ENGINE-Turbo_Brake_Booster_Heat_Shield_Removal/70-ENGINE-Turbo_Brake_Booster_Heat_Shield_Removal.htm
Old 07-11-2018, 02:23 PM
Thanks for the info. It's not the brake booster heat shield. This heat shield fits "on" the engine carrier with two bolts and covers what appears to be an air hole.
Neither parts catalogs show this part anywhere that I can.
Any other ideas. I'm stumped!!
Old 07-11-2018, 03:14 PM
soxnail's Avatar
Would it be in this region ?
Sox
"Little problems always come back and bring bigger friends with them".
1986 951"MADDOG" black
Dual port WG, 4 port control valve with EBC
Old 07-11-2018, 04:59 PM
That's close. It fits supposedly just down below the turbo on the engine carrier. If you folks haven't seen it before I guess I'm out of luck. Thanks for taking the time to respond.
Thanks,
Ed
Old 07-11-2018, 09:13 PM
soxnail's Avatar
Looks like a "after market" kind of like mine in the pic above I made mine from steel shim stock.
Sox
Old 07-12-2018, 08:06 AM
That bit of heat shielding goes over the steering column, below the turbo.
I removed mine when swapping the turbo... I had to pull the shield from above, to help access the two bolts from underneath that actually hold the turbo to the engine mount / turbo pedestal. It should bolt on right near where the universal joint is in the steering column.. two small bolts that fit into tapped locations.
Old 07-14-2018, 09:51 PM
Super Moderator
nize's Avatar
that's the heat shield cover plate for the steering shaft. it protects the u-joint grease from the hot turbocharger. if i remember correctly, the bolts are accessed from above. Part Number: 95110112900 (no longer available!)
you can see it in the diagram here:
https://www.porscheatlantaperimeterparts.com/showAssembly.aspx?ukey_assembly=475690&ukey_make=1 058&ukey_model=15414&modelYear=1989&searchString=s teering
you can also see it here as part# 45:
http://old.utzon.se/upd/42/197/8/4/8040302
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!)
Old 07-15-2018, 09:44 AM
