Kd even though I have new hoses on all the cooling system (full hose kit from 944Online). I am kind of leery of taking of hoses and putting them back on, i seem to get a leak at that point sooner or later afterwards. Maybe I am torquing the clamps too much....
Sox
"Little problems always come back and bring bigger friends with them". 1986 951"MADDOG" black Dual port WG, 4 port control valve with EBC |
So to further this particular thread, I have a question this time for a hint.
Has any body figured out how to take the oil filter off without drenching everything under it with oil? Every time I do it I spend the next 30 mins with long forceps and paper towels getting the oil out of all the places it gets to. Sox Ps. I have tried to stuff rags/paper towels under the filter to catch the oil with mediocre results.
Banned
Use a oil filter wrench with a drain pan or a rubber grommet to seal the filter when removing. You can also try pre-draining some oil from the filter by loosening it slightly before completely removing.
The newest of the noobs!
I just did an oil change on my ride, I usually fill the Mahle filter a bit before screwing it on. As I’m old, I couldn’t recall if you could fill the whole filter. This time it didn’t take much. At speed, I get 4.5 bar, and usually, at idle, 2.5-3 bar. Now, it’s 4 bar. I use VR-1 29W-50. Normal, or is the oil filter getting bypassed? If possible of course.
Can you post a pic of your oil filter wrench with drain pan or grommet attached ? Thaks Sox.
Sox
