Engine block question
I have a 87 busted turbo block. Does anyone know if I can use a regular 944 block given that I put all the parts in it from the turbo? I have an 86 core.
Yes, you can. I use an 83 NA block for my 86 turbo build.
Gone but not forgotten: 1971 914 First Car (SOLD) | 1972 914 rust bucket (SOLD) | 1986 944 Turbo (Murdered by a Chevy Truck on the freeway) Current lineup: 1990 944 S2 Cabriolet - Long term project | 1971 914 - Long term project #2 | 1971 914 - Driver |
had to replace my block when I rebuilt my 86 951 engine. from research you can use early blocks, but I read they are not as strong as 86 and up from when the turbo came out. for 86+ even if they are from a NA car they also have a tap on the balance shaft cover for the turbo oil line. on the early blocks you have to create a way to feed oil to the turbo.
I was going to use a block from a 87 924S parts car I have but found a good 86 951 engine for the rebuild. also read the 86 is the best / strongest block, after that porsche started trimming it down. all comments from reading so do the research yourself to confirm.
Bob Cox 78 930 clone project car. 87 924S resurrect at some point. 84 928S, Ruby Red linen/brown interior - sold ![]() 86 944 turbo my new DE/track car - sold
Super Moderator
some more reading here: 88 944 turbo S question
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!) |
Kessel run in 12 parsecs!
Getting old sucks, bring back the good old days, this new stuff is for the birds.. |
Super Moderator
don't throw that cracked block out: you could darton sleeve that cracked block and make a 2.7 liter.
![]() 2.7 darton wet sleeved motor with custom JE pistons
Well, my brother threw a brass fitting in the block through the spark plug hole. That’s how it happened. Never thought one can be so evil. They say karma is a b…h. I’m sure he will reap what he sows.
I’m switching the block now from a non turbo car. |
Ahhh, thats pretty cold doing that. I was wondering about those gold flakes down there. That image had me worried about my engine over heating or something, that was clearly mechanical, WHEW!!!!!
