Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
porsche speed's Avatar
Engine block question
I have a 87 busted turbo block. Does anyone know if I can use a regular 944 block given that I put all the parts in it from the turbo? I have an 86 core.
Old 05-20-2021, 10:17 AM
Yes, you can. I use an 83 NA block for my 86 turbo build.
Gone but not forgotten: 1971 914 First Car (SOLD) | 1972 914 rust bucket (SOLD) | 1986 944 Turbo (Murdered by a Chevy Truck on the freeway)
Current lineup: 1990 944 S2 Cabriolet - Long term project | 1971 914 - Long term project #2 | 1971 914 - Driver
Old 05-20-2021, 04:25 PM
911tracker85's Avatar
had to replace my block when I rebuilt my 86 951 engine. from research you can use early blocks, but I read they are not as strong as 86 and up from when the turbo came out. for 86+ even if they are from a NA car they also have a tap on the balance shaft cover for the turbo oil line. on the early blocks you have to create a way to feed oil to the turbo.
I was going to use a block from a 87 924S parts car I have but found a good 86 951 engine for the rebuild. also read the 86 is the best / strongest block, after that porsche started trimming it down.
all comments from reading so do the research yourself to confirm.
Bob Cox
78 930 clone project car.
87 924S resurrect at some point.
84 928S, Ruby Red linen/brown interior - sold
86 944 turbo my new DE/track car - sold
Old 05-21-2021, 10:28 AM
Super Moderator
nize's Avatar
the best/strongest blocks are the 951 turbo-s blocks designated as m44/52 stamped right on the block itself. these blocks were available in the s-model starting in mid 1988 and have additional strengthening designs the earlier blocks do not have.
some more reading here:
88 944 turbo S question
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!)
Old 05-22-2021, 07:21 AM
Kessel run in 12 parsecs!
Fast Freddy 944's Avatar
Wow! How did you do that? I have never seen a cylinder cracked like that. Now Im officially worried about my car!!!
Getting old sucks, bring back the good old days, this new stuff is for the birds..
Old 05-23-2021, 08:18 AM
Super Moderator
nize's Avatar
don't throw that cracked block out: you could darton sleeve that cracked block and make a 2.7 liter.
2.7 darton wet sleeved motor with custom JE pistons
Old 05-24-2021, 04:21 PM
Well, my brother threw a brass fitting in the block through the spark plug hole. That’s how it happened. Never thought one can be so evil. They say karma is a b…h. I’m sure he will reap what he sows.
I’m switching the block now from a non turbo car.
Old 05-30-2021, 07:21 AM
Ahhh, thats pretty cold doing that. I was wondering about those gold flakes down there. That image had me worried about my engine over heating or something, that was clearly mechanical, WHEW!!!!!
Old 05-31-2021, 07:47 AM
