Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
Internally leaking injector
I got my 1985.5 944 about 4 months ago not driving but the engine ran. In those 4 months I’ve replaced the clutch tires brakes and gas tank. I got it driving but I’ve came across a small problem that I have yet to find a good solution for.
One of my injectors is leaking from the body not the two o-rings on the top and bottom of the injector, but the part of the injector where the spray nozzle connects to the body of the injector.
I thought that a rebuild company that specialized in refurbishing injectors could help but they told me that if it leaks from the body they cannot do anything to help.
Does anyone know if there is a rebuild kit that includes internal seals, because I know that some other models of injectors you can replace internal seals to the injector.
Any ideas to fix the leak or any ideas where I can buy “new” refurbished injectors would be appreciated!
Old 10-01-2024, 03:53 PM
In the Fires of Hell.....
kdjones2000's Avatar
Post this in the 944 (not 944 turbo) section, and I am sure someone has a spare injector you can acquire.
FYI, I'll bet a simple injector seal kit will fix your problem. Get one from the dealer, e-bay, or maybe even your local auto shop.
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 10-01-2024, 04:45 PM
