Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
boost question.
O.k. I have had the turbo s checked out. Leak down cylinder 1=3% drop, 2cylinder = 2% drop, 3 cylinder= 3% drop, 4 cylinder=3% drop. Compression #1= 145lbs, #2=145lbs, #3=140lbs, #4=140lbs. Two leaks 1 at pressure relief valve at oil filter. 2 at back of cam housing. Round gasket with tabs. Both are minor. Finally the boost tops out at 1.1 at 3700 rpm. This seems low. What do you guys think about this data?
Old 11-07-2003, 10:36 AM
The comprression has nothing to do with the boost. I suspect a vacuum leak somewhere that is not allowing your turbo to spool up properly.
Check all those little vacuum line to start with. Make sure they are all connected. Let us know what you find.
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 11-07-2003, 01:11 PM
clarification
The leak down and compression figures were just there for your comments. I don't think they had anything to do with the boost. I would like to know what you guys think of everything but especially the "low" boost
Old 11-07-2003, 01:48 PM
I already did. Check the vacuum lines. They control the boost - assuming your boost gauge is correct.
Boost should be 1.8 bar on gauge. If not, something is wrong. Probably what controls turbo which is vacuum.
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 11-07-2003, 02:32 PM
1.2 on the stock gauge is also 'boost protection mode'
do a search on 'blink codes' and check them to see if you have a fault
throwing you into 'limp home mode'
1988 951 Alpine White / Burgandy
Profec B spec II EBC,HomeBrew Chips, WideFire HG, Tial 38mm, Magnecor Wires, Koni Rears, Adj Rear Droplinks, Zeitronix WideBand.
Old 11-08-2003, 03:32 AM
vott does ziss do?
ronin's Avatar
no blinky on the 86. wasn't available until 88
Old 11-08-2003, 06:14 PM
Wolf1's Avatar
So what is the magical, mystical, profound procedure for retrieving these blinky codes?..
75 914 - Undecided.
80 931 - Gone, but not forgotten.
72 914 - old toy- sold.
And a whole bunch of German scrap metal shaped like 924's.
Old enough to know better, and stupid enough to do it anyway!
Old 11-08-2003, 06:17 PM
vott does ziss do?
ronin's Avatar
on the late 88s and up you use the Porsche shop diagnostic tool. there is also a blink code tester available but Britwrench told me that it wasn't worth a squat
Old 11-08-2003, 06:21 PM
Wolf1's Avatar
So the average guy like me, with the average tools like Snap-on scanner, Tech-1, Tech-2, Star tester, DRB-III, and sun scope & emission machine is just out of luck? I guess I was hoping for: jumper this wire to that wire and count the little flashy's.....
75 914 - Undecided.
Old 11-08-2003, 06:31 PM
vott does ziss do?
ronin's Avatar
well, tellyawhaddimgonnado. before I put my foot in my mouth I'll check the manual as I am not 100% sure. lemme see what I can find out
Old 11-08-2003, 06:33 PM
Wolf1's Avatar
cool
75 914 - Undecided.
Old 11-08-2003, 06:39 PM
Wolf1's Avatar
Thanks.
75 914 - Undecided.
Old 11-08-2003, 06:40 PM
vott does ziss do?
ronin's Avatar
well, the manual says that the DME from a m.y. 88 S is capable of self diagnosis using the Porsche 9268 diagnostic tool. but the blink code function wasn't available until 91 when Calif. legislated that all cars must have a visual warning when emissions components malfunction
Old 11-08-2003, 06:43 PM
Wolf1's Avatar
Damn, so there is no way for me to check codes?
75 914 - Undecided.
Old 11-08-2003, 06:50 PM
vott does ziss do?
ronin's Avatar
apparently not. there is a little something that I was working on by seeing whether it would be possible to re-do the DME to accept the 88 software for being able to have the diagnostics feature
Old 11-08-2003, 06:57 PM
The 86-on turbos do have the blink code test. To do this you must first drive the car untill it goes into it's safe mode (~1.2 bar) or just start and run the car if you are just checking for other faults. Then while the ignition is still on, connect a led to the test port and start counting the blinks. Once you turn the ignition off, the error codes are erased and the DME is (essentially) reset.
Danno of guru racing has an excellent write-up done on his web page. Here is the link to that write-up.
Rob
Old 11-08-2003, 07:23 PM
vott does ziss do?
ronin's Avatar
ahaaa. this is getting better by the minute. I didn't realize that you actually could get blink codes from the earlier DME. one thing to remember is to do the test while the car is still on as turning the ignition off will clear the DME
Old 11-08-2003, 07:45 PM
A common thing to throw you into protection mode is a bad TPS.
The blink coded will tell you that. Just make sure you keep it running
as the reset when ignition is turned off.
Also check for a bad cycling valve. If it's stuck or broken you will be stuck with the same low boost with no fault codes.
Old 11-09-2003, 03:02 AM
Mike B's Avatar
Re: boost question.
By the way, those are very acceptable leakdown and compression numbers.
'86 951
'88 928S4 - the project
Old 11-09-2003, 06:58 AM
I still say it's vacuum related. A ruptured diaphragm in the valve near the coolant reservoir will prevent proper boost. If the vacuum line comes off or is broken, you only get about 1.2 on your gauge. A broken diaphragm does the same thing.
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 11-09-2003, 07:09 AM
