Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
Porsche Crest problem with putting engine in
hey guy i have 87 944 turbo and i have the motor out and i am trying to put it in but i cann't get the drive shaft lined up to go in to the fly wheele housingcan you help me out and tell me how to get it in.
Old 03-01-2004, 10:15 AM
Wolf1's Avatar
Option #1...remove crossmember to allow engine to drop down.
Option #2...remove transaxle and slide torque tube back.
Option #3...bend driveshaft or damage clutch attempting to force them together at an angle.
Try to avoid option #3......
75 914 - Undecided.
80 931 - Gone, but not forgotten.
72 914 - old toy- sold.
And a whole bunch of German scrap metal shaped like 924's.
Old enough to know better, and stupid enough to do it anyway!
Old 03-01-2004, 08:08 PM
how hard is it to remove the torque tube and transaxle
Old 03-01-2004, 08:10 PM
Wolf1's Avatar
The transaxle is pretty easy to remove.........then the torque tube can be slid back a few inches (helps alot)
To completely remove the tube would require removing the rear suspension/torsion tube. (not as easy)
When you slide the tube back, you will notice it will only go a few inches, then catch on the torsion tube. I have heard that spinning it over will allow a few more inches (have not tried this)
75 914 - Undecided.
Old 03-01-2004, 08:20 PM
about how far back will it move the transaxle and torque tube that way i will know if i have to do any thing else to make room
Old 03-02-2004, 10:53 AM
how do i take the transaxle out to move the torque tube back
Old 03-03-2004, 11:05 AM
I've never had a problem installing the engine in a 944.
Never removed any crossmembers either.
Seem to go right in.
I've done this so many times.
Old 03-21-2004, 06:48 PM
I'd like to know how to install or remove a 944 engine without removing the front cross-member
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 03-21-2004, 08:10 PM
"I've never had a problem installing the engine in a 944.
Never removed any crossmembers either."
Dude, no way you're gonna slide the engine forward 8 inches to clear the drive-shaft without dropping the crossmember!
hawkster, did you use a clutch-centering tool to make sure the clutch-disc was centered on the crank & pilot-bearing before you clamped down the pressure plate? Also having a leveler makes it 10x easier to tilt and angle the engine.
Old 03-25-2004, 04:19 AM
