first oil change, how many quarts should my 951 take?
I just changed my oil and added 6 qts, still 1 quart low. Is this correct that this 4 cyl is supposed to hold 7 qts? Seems like alot to me but just wanted to check so I don't overfill it if my dipstick is somehow off. Thanks
Dog-faced pony soldier
7 is about right. I forget the exact metric value (both the metric and imperial conversion are given in the manual) for it, but I believe it's like 6.92 quarts with the filter or something. I believe I just dumped in 7 on my last change - close enough for me.
A car, a 911, a motorbike and a few surfboards Black Cars Matter |
Thanks for the reply. I'll add another quart today then. I just figured that was a lot of oil for a 4 cyl so just wanted to double check. Thanks again
If your 951 came with an forward oil cooler it is going to take more like 7.5+ quarts with the short standard oil filter.
My 944 na takes 6.5 quarts...
1974 914 1.8 Sold... 1984 944 my baby...more of a pain in the @$$ than takin' it with a cucumber, but I still love it. THE CAR YOU PERVS!!!!!!!!!!!! 1990 Nissan 240sx fastback aka Japanese 944 |
No, the 944T uses the later dipstick which increases oil capacity. There is a technical bulletin about this to retrofit early (which would only be NA) cars. When the oil in a 944T is drained, whatever is in the oil cooler stays there unless you disconnect and drain it.
From November 2012; Precision Porsche Specialist Sussex UK, +44 (0)1825-721-205 2001-2012 Gerber Motorsport Inc. 206-352-6911 07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red 08.16.09 1999 Kawasaki ZRX1100. Green. |
