e codes
i searched for any info on e codes for a 951, but i couldnt seem to find anything. i was wondering what others were using headlight wise in their cars.
any suggestions or comments would be much appreciated, thanx! |
Ornery Bastard
Either Hella or Cibe ECE-Spec lenses. Anything else will cause glare for oncoming drivers. Expect $100 to $200 for a pair.
I have a pair of Hella E-Code headlights in mine and they're exceptional. Aaron
--------- Silver 1998 Volvo S70 T5 <- Daily (Anja) Guards Red 1986 951 <- Seattle car (Gretchen) White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei) |
awesome i appreciate your help! my i ask where you found them?
Ornery Bastard
I came across them on E-Bay. I've also seen them by searching Google. Just have to watch and make sure that you're getting actual Hella or Cibe and that they're actual ECE-Spec.
Some trivia on an E-coded alternative... http://arnnworx.com/lighting.htm
Bruce
87 951 (All stock commuter) 87 951 (Saturday night Special) 77 911S (token tail dragger) 83 928S (engine back in from tear down, interior gutted) ....Grasshoppah |
Bruce, very nice write-up! That'll come in handy now that Dan (Iceshark) is no longer with us.
There are a couple of things I'm wondering: * what gauge line did you use? I remember reading something about the stock wiring being a real bottleneck -- especially going to 100/80w or 130/90w. * why a single ground point for the headlights (why a ground line going from the passenger side all the way across to the driver's side)? BTW -- in the States, these guys have Cibie E-codes in stock: http://www.talbotco.com/ -- $49/ea
Joe Chen Current fleet: '93 Amethyst Violet 968 Cab "Lila" (back in the fleet!) ; '92 Cobalt Blue 968 Cab "Minjonet" - Canadian car '88 Silberossa 951S "Rosy" - garage queen ; Secret project ; '99 Ford Ranger ; '00 Kawi ZX6R Former cars: '94 Black 968 Cab "Steffi" (totaled) ![]() ![]() |
Ornery Bastard
Also, if you keep the stock wattages, you won't need to run the relays. To be perfectly honest, stock wattage with an ECE-spec reflector should be more than fine. It's really just the reflector in the sealed-beam units that sucks.
'86 951 blk/blk -968 M030 Sway Bars with delrin bushings -IceShark headlight kit -Koni Yellow Sport Adjustable struts and shocks -225 lb springs up front Cleaned grounds = happy 944 WTB: 951 black passenger door/fender |
This place has hellas for $72 a pair with bulbs: http://www.rallylights.com/hella/7in.asp I'm not sure whether Hellas or Cibies are better, but that seems like a reasonable price.
Stock 1988 951, TT aero wipers |
Everything you ever wanted to know about automotive lighting:
http://www.danielsternlighting.com/ |
Todd,
Do you know anything about Daniel Stern? I tried emailing them several times about purchasing their products but never got a response. I'm wondering if they have my ISP blocked for spam or what.
Ornery Bastard
Super Moderator
fyi, myself and a few others are planning on duplicating the complete iceshark full-boat kit in the near future, possibly sometime this summer.
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!) |
I emailed Daniel Stern a month or two ago about ordering the e-code lights, and I got a prompt reply. Could be that your ISP is blocked for some reason. Make sure you check out the info in the "tech" section of the site. There's a lot of interesting stuff there that I haven't seen anywhere else.
