Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
Question Still no solution?
As some of you may know I put a K27 and an Autothority Mass Air kit on my 88 turbo S. Shortly after that I blew the factory head gasket. Replaced the head gasket with a wide fire and got it all put back together. This is the deal, I am getting way to much fuel. I mean its enough fuel that you can see it setting in the piston relfs when you pull the plugs. I just replaced the pop off valve and a temperature switch for the turbo, but that did no good. What would be causing this overly rich mixture? HELP!!!!!!!!
Old 10-16-2001, 05:07 PM
wolfrpi's Avatar
Post
check the fuel pressure - also what kind of injectors are you using?
Old 10-16-2001, 05:32 PM
Post
Ive checked the fuel pressure at the fuel rail and it is ok. Im tryn to get some info from Autothority about how to check thier mass air sensor, but no reply yet. They said they would send me some info, but that was over a week ago. Gona pull the chips out of the dme and klr and put another set in and see what happens.
Old 10-16-2001, 06:13 PM
wolfrpi's Avatar
Post
1) What fuel pressure are you running?
2) What size injectors?
Erick
Old 10-16-2001, 06:23 PM
