Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
Jeff Alton's Avatar
low boost problem
I have done lots of searching here and on rennlist but need some help. Car is and 87 951 and has a low boost issue. It makes about 8psi max. Motor is stock.
Idle vacuum is about 16hg
Deccel vacuum is about 21-23hg
When I clamp the line to the wastgate I get 12 psi max.
BOV holds vacuum.
My searching tells me my wastegate is okay, is that right?
Where should I look next? Besides a cold motor stumble/hesitation the motor runs well (other than the lowish boost numbers). I have replaced a majority of the vacuum lines and tested the intake manifold gaskets for leaks.
Thanks for any insight....
Cheers
www.turn3autosport.com
Old 06-29-2006, 11:07 PM
Check the 3 rubber hoses downstream of compressor. There are two at the intercooler (pre and post) and one large one where the compressed air leaves the compressor. Remove the one at the compressor to have a good look at it.
There is also a rubber section right at the throttle body but I've never seen one of these split.
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 07-02-2006, 03:38 AM
Jeff Alton's Avatar
Thanks, I will be looking there next! Is there commonly available silicone replacements for these couplers, or is factory original the way to go if they need to be replaced?
Cheers
Old 07-02-2006, 08:17 AM
Engine swap pro
myskyon's Avatar
Re: low boost problem
When I clamp the line to the wast-gate I get 12 psi max.
BOV holds vacuum.
My searching tells me my waste-gate is okay, is that right?
Cheers
http://www.clarks-garage.com/shop-manual/exh-02.htm
um your waist gate is bad. when you clamp the line to the waist gate it should send your boost to over 20psi. i would look at the waste-gate. as for the cold motor hesitation /stumble let your car warm up for a couple of min before driving
87 951 ---- "R2" - under the knife
87 951 ---- "R1" Parting out - Gave to a good friend
88 951 ---- Black one - recieved as a trade for my 87 - very mint - parting out
06 WRX ---- The "RUE"
Old 07-02-2006, 09:07 AM
SD Porsche Fan's Avatar
My cat. conv. truned out to be the culpret when I had low boost issues. It was nearly clogged as the PO ran low octane fuel and had a bad O2 sensor. Installed a cat bypass and went from 8 to 12 psi boost. Huge difference.
'89 951 Alpine White/Blue, factory sport seats, Lindsey DP WG, MBC, Vitesse chips, 3 bar FPR, Evo diverter valve K&N filter, cat bypass, Koni Yellows
Old 07-07-2006, 04:26 AM
Jeff Alton's Avatar
Thanks guys!
Cheers
Old 07-13-2006, 09:39 PM
Super Moderator
nize's Avatar
how do you know what psi you are getting? do you have an aftermarket gauge ?
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!)
Old 07-17-2006, 05:08 PM
Jeff Alton's Avatar
Aftermarket gauge installed in the car, I think the WG is pooched, I have a spare one now and will put it in and see if this solves the problem. I have to do a water pump and belt service first so it will be a few days, but I will report back with my findings!
Thanks to all who offered up some help
Cheers
Old 07-20-2006, 06:43 PM
