Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
weird problem!951
Guys I need some help !!!
I have 951 1986 I test drove car yesterday in 100mile trip, car has a problem, always show when car is warn up, for example in 4 gear at 4000rps just crussing speed 75 and you kind feels car is not keeping power then you put gas and car dosn't react !pump gas pedal couple times and then it acts weird and the goes fine again! when this happen you push gas pedal and engine feels like if not getting fuel in to, even the boost gauge dosen't show rise in boost for 1 or 2 seconds and then it rise boost and seems to operate fine I check engine and it looks like the TPS sensor has the tap missing you can see the little wires and things inside !also my air filter housing is most taps broken and air filter is not 100% secure !main question should this tps be problem !or look something else
1986 951 silver/black
Old 04-27-2007, 03:31 PM
Super Moderator
nize's Avatar
1) replace tps with a known good one.
if this doesn't work;
2) remove injectors and have them professionally cleaned and flow-matched.
www.witchhunter.com
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!)
Old 04-28-2007, 12:11 AM
Ernest Hill's Avatar
my car started doing this then got worse now i'm standed; did you figure out what was wrong?
Trust no one who does not drive a Porsche daily. just kidding. Sort of
Old 06-01-2007, 05:04 PM
winter-hater club member
nynor's Avatar
Re: weird problem!951
um... in the pictures you posted earlier, the TPS didn't have the top on it... frankly, my boost doesn't respond for about 2 seconds when i hit the gas (unless i am already into the throttle), so i don't know what this has to do with the 'problem'.
"COOL PRIUS!" - Nobody Ever
Old 06-01-2007, 05:17 PM
