Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
Ernest Hill's Avatar
stranded please help
i'm stranded in roswell NM. my 86 951 will run perfectly cold; once warm, it will start and idle no problem, and rev if you pull the throttle by hand, BUT if you push the gas peddle under load it will hesitate then fire-- at first; after driving several minutes, it will simply drop down to idle and stay there; it will roll along top speed 20mph until cool again.
fuel pressure: 28 to 35 psi
air flow meter is working
throttle position sensor is working
amps at the battery ~13
new alternator
just replaced column switches
just fried 3.5 year old battery w/ plenty of electrlyte
cd player is malfunctioning
horn relay is very hot
turbo water pump is new and the relay works but it is not coming on
any ideas? thanks for reading
Old 06-01-2007, 05:43 PM
winter-hater club member
nynor's Avatar
fuel delivery problem, causing knock, perhaps?
"COOL PRIUS!" - Nobody Ever
Old 06-01-2007, 05:55 PM
no knock, and pressure is just below specs (33-39psi)
Trust no one who does not drive a Porsche daily. just kidding. Sort of
Old 06-01-2007, 05:57 PM
nynor's Avatar
vacuum leak.
Old 06-01-2007, 06:21 PM
no broken hoses, visible clamps all tightened; are there other vacuum leak possibilites? what does the heater valve control?
Old 06-01-2007, 06:34 PM
nynor's Avatar
on a 951, all kinds of hoses under the intake manifold. check the rubber intake boots, double check the rubber intercooler hoses, check the BOV and the rubber parts that connect it to the intake.
Old 06-02-2007, 06:40 AM
soxnail's Avatar
Re: stranded please help
How do you know this ?
Same question.
Don't understand this one.
new alternator
Don't under stand this.
Don't care
could be a short, but wont keep you from running.
You will reduce the life on the turbo, but again wont keep you from running.
Vacuum leak should show up as bad idle and not be temp related.
You need to make sure that the TPS is working when the engine is hot.
Ditto on the airflow meter.
Also is there any smoke or unusual emmision from the exhaust ?
Sox
"Little problems always come back and bring bigger friends with them".
1986 951"MADDOG" black
Dual port WG, 4 port control valve with EBC
Old 06-02-2007, 04:27 PM
TPS is brand spankin new; no emissions; can anyone tell me exactly how to test the AFM? i have a new very expensive one in my hands but i would pre fer not to waste my money when the mechanic here thinks the AFM is working and i already blew 200 replacing the TPS
Old 06-03-2007, 11:14 AM
nynor's Avatar
plug the new AFM in and see what happens. no harm done.
Old 06-03-2007, 11:50 AM
My guess was going to be the TPS, have you tried reading the blink code?
Lou
'87 944 na, sold to a friend
'89 951, Weltmeister chips, 3mm WG shim, 968 CS sway bars, stock looking engine bay, just turned over 125K miles. I run Redline oil.
Old 06-03-2007, 06:29 PM
you're not gonna like this, but you could have an issue with the DME. A cold solder joint or failing Injector driver could cause this.
Also, try disconnecting the O2 sensor and see what happens.
1988 951 Alpine White / Burgandy
Profec B spec II EBC,HomeBrew Chips, WideFire HG, Tial 38mm, Magnecor Wires, Koni Rears, Adj Rear Droplinks, Zeitronix WideBand.
Old 06-04-2007, 12:00 PM
nynor's Avatar
yeah, i was going there next. is there someone you can borrow a DME from?
Old 06-04-2007, 02:01 PM
